Old 06-28-2012, 01:25 PM
NewVista's Avatar
NewVista NewVista is offline
Finally have pic of '59 Zenith up (scroll up to post)
It's P/P 6BQ5 Stereo + Mono FM w/ variable reverb
Stunning French Provincial cabinet.
Have replaced all wax paper caps so she runs well
Old 07-03-2012, 11:10 PM
NewVista's Avatar
1947 Magnavox has FM option, strong P/P 6L6 Amp, dual 12" EM speakers
Old 07-04-2012, 12:55 AM
These are all fine looking models. One day, I'll get together some pictures of mine.
Old 07-04-2012, 03:19 PM
Here are two I just picked up. The first one is a '68 Magnavox Astro-Sonic that an elderly couple at my church gave me because they are wanting to move to an assisted living center. The next one is a GE from around '46-'47 that has the early version of their VR magnetic cartridge in it.
Old 07-04-2012, 03:22 PM
Here's a BOTL '66 Arvin solid state consolette record player with a BSR record changer.
Old 07-04-2012, 03:25 PM
Cheap Tonecrest console from '64.
Old 07-04-2012, 03:29 PM
Probably the nicest console I own, a 1960 Motorola.
Old 07-04-2012, 03:31 PM
1960 GE Phonograph console
Old 07-04-2012, 03:32 PM
Early '60's Packard-Bell console.
Old 07-04-2012, 03:34 PM
Circa 1957 Magnavox mono record player consolette.
Old 07-04-2012, 03:36 PM
1960 Magnavox console.
Old 07-04-2012, 10:28 PM
NewVista's Avatar
I like these historic pieces that recapture an era
The BIG Motorola's offered serious sound for an aspiring
affluent mid century middle class.
Inspires me to get my Motorola running (one advantage is
they use ceramic Caps, so no paper caps to change)
Old 09-14-2012, 10:23 AM
DavGoodlin's Avatar
Motorola Minion
Found a Sylvania Console at GW
Model SC374K from 1971. This seems to be the only appropriate location to post. Price tag says $25.
I know its not a tube set but it is very clean looking early American cabinet, stamped on back " cabinet made in Canada" and has a Garrard turntable and slider vol-bass-treble controls.
I was going by the Goodwill near home the other day and it was calling to me "help- here I am, old and lonely - nobody likes me here among the BPC"
I will post pics, visiting it for 2nd time on way home.
Sylvania anything is rarely found here and IMAO, unfairly
underrated, with GE getting way too much credit and sales.
Should I rescue it?
Old 11-14-2012, 09:36 AM
Phototone Phototone is offline
Originally Posted by Jeffhs View Post
What can go wrong with the cutting heads used in those old record cutters?
There were 2 types of cutter-heads used in home record recorders. Probably the most common was a Crystal cutter head, which used a Rochelle salt crystal similar to the crystal in common phonograph cartridges of the period, only much larger. It would deform under voltage and thru a mechanical link to the cutter stylus provide the drive to cut the signal in the acetate blank disc. As with all Crystal (not ceramic) cartridges, the crystal element deteriorates with time and in most cases is not useable at this point.
The other common style would be a magnetic cutter head. It works just the same, and unless the coil is open should be a candidate to repair.
Both types would have rubber suspension parts that would be deteriorated and hardened and would need to be replaced. The armature that holds the cutter needle would be cradled in a rubber sleeve of some sort.
Most of these cutters designed for consumer recorders were designed to be driven by relatively low-power amplifiers, in general the same amplifier that provides the play-back audio.
Replacement cutter heads were still offered in Allied and Lafayette catalogs as late as 1965, but these may have been remaining stock.
Old 11-14-2012, 12:52 PM
How cheap could it be! Look at the size of that power transformer!
It's better than some of the Zeniths I've seen.
