Old 12-13-2014, 09:10 PM
It is important to have a good H osc. tube, but I don't think that is the MAIN problem with horizontal hold.
What I hope you have or are willing to get is the sam's and a diddle stick (a small PLASTIC* hex key). *If you use a metal one you are likely to crack the slug, and it is harder to adjust since the metal acts like part of the slug, and once you pull it out your adjustment will be off.
You need to adjust the horizontal osc slug to dial in the hold...You see the front H hold pot on most sets is a fine hold control, the coarse hold being the slug(s) adjustment. Don't just randomly adjust it, follow the sam's procedure since there is the potential of damaging the fly if it is badly out of adjustment.
Old 12-14-2014, 02:55 AM
tvcollector's Avatar
I have the Sams. I don't have a plastic hex key, nor I don't know where to get one either... Is this something I could get at a local place like Radio Shack or Home Depot, or something that needs to be ordered?
Old 12-14-2014, 09:04 AM
A GC Electronics 8454 is all you need for color TV servicing - about 8-10 dollars at most places.
Dealer net is 8.99, so don't pay more than that.
USN RET 22YRS (Avionics/Cal)
Old 12-14-2014, 10:47 AM
You can probably order a set from Moyer's. They can ship it in a Jiffy bag, so postage shouldn't be too high.
For an unloved set, eight pages of responses.
Old 12-14-2014, 01:56 PM
Make sure to get a new osc tube too. If it is weak then it's only a matter of time until it fails and H drive is lost...When that happens the HO Tube will red plate and both the output and flyback will be at risk of permanent damage.
Get the tube in before adjusting the osc. slug so that you don't have to readjust it for the new tube.
Old 12-14-2014, 02:29 PM
Thanks for the info.. I'll have to order that GC Electronics 8454.. I've already got a 5 pack of 6BH11 tubes coming..
Old 12-14-2014, 04:45 PM
Moyers doesn't have this listed on their site, nor nothing comes up when searching.. Nothing seems to exist "dealer net".. All other sites that do come up with this on Google require a minimum order of $10 - $30.. I tried eBay but this particular unit is not on there..
They have it here, but the ups shipping is more than the tools
http://www.amusementsplus.com/index....ub=743&id=2274
Old 12-14-2014, 06:36 PM
Paul Knaack Paul Knaack is offline
http://www.ebay.com/sch/i.html?_saca...nt+tool&_frs=1
http://www.ebay.com/itm/ELENCO-ST-13...item3f3ceb46d5
Hope this helps
Old 12-14-2014, 06:50 PM
That eBay link I already sent them a message.. It happens to be local (20min drive)
Old 12-15-2014, 03:11 AM
I'm reading the Sams under misc Adjustment - Horz Sweep circuits.. It's telling me to connect a 0-500ma meter to in series with cathode lead of Horz Output Tube and .47 mfd cap across the meter.. Then it says to connect a 0-1500 meter in series with the cathode lead of HV regulator tube.. Then tells me to adjust some controls and one being the horz osc control and some measurements.. At this point I'm already thrown completely off.. It does say to adjust the horz adjustment on the TV set control to the middle.. So that I'm aware of.. When I looked under the set where the 6j56 horz output tube is, i saw metal jumpers under the tube socket that connects to different pins.. looks like that would need to be unsoldered to connect amp meter in series.
I could either let Dave take over from here and restore the set, or attempt myself.. I've gotten this far.. Looking at the old coil, the slug is adjusted way down into the coil verses this new one, so I could either adjust the slug on the new coil to around where the old one is, then turn the set on, and slightly adjust right/left until I lock horz in.. Or I could be walked through on where to connect the meter.. Which I'm not expecting anyone on here too..
Old 12-15-2014, 11:17 AM
earlyfilm's Avatar
Eternal Member
Don't be tied to one brand. A search on ePray for "TV Alignment Tools" turned up 4 hits from three sellers for $6.22 to $7.99, all with free shipping.
Auction numbers:
111529297027
271687189179
271604991701
331103970391
I have no connection to any of these sellers.
James.
Old 12-15-2014, 12:44 PM
I have a brother that works for a local electronics dealer and he got me the GC dealer net. GC lists a distributor price (I'm not privy to this, nor is my brother) and a dealer net, what his company sells them at. I'm not recommending any particular vendor - do a Google shopping search. For all intents, I avoid Moyers (Mecosun on eBay) and their outrageous prices for parts.
GC has made these alignment tools for decades. Avoid the polypropylene chinese crap on eBay - you will be disappointed. As for me, I have GC's Master alignment tool set, a whopping 51 dollars in 1987, when I bought mine. Now they are about 120 bucks, and are beyond what anyone would need these days.
eBay item 111529297027 is the set I was referring to - and it is not mine/no affiliation to the seller.
Old 12-15-2014, 12:59 PM
The exact procedure may help me to dissect it into it's constituent parts, but I'll try to give you a general breakdown. Usually sam's rolls adjustments of the various sections in and effected by the horizontal into a single procedure when they could be done one at a time. Usually it starts by adjusting the oscillator (which is what you most need to do), then it goes into horizontal linearity/efficiency adjustment* followed by HV adjustment*#.
*The .47 cap and meter thing is this part. While it is not ESSENTIAL that you do this part, you should because it checks the current through the HO Tube into the fly and minimizes it to prolong the life of those parts. What you need to do is trace the HO Tube base pin out from the schematic, and find the cathode lead (which should go to ground) break that ground (make sure you do NOT break heater ground too as it will mess up the adjustment) and insert the cap and meter (I prefer to use an analog meter[mine is from Rat Shack] with about a 250mA DC scale) then adjust the H linearity/efficiency coil slug for minimum current (usually between 185 and 210mA). On some sets there is a 250mA fuse in series with the ground you want to break if there is not one in your set you may want to add one to protect the flyback...If you do mount it above chassis where it is easy to check, change, and remove to re-do the linearity procedure/current check.
*#If you don't have an HV probe then don't try the HV section of the procedure....There may be ways of checking and adjusting the HV without a probe, but the sam's HV procedure should be considered invalid if you lack the proper measuring equipment for it.
To be honest with you I always do the first two pieces of the horizontal procedure (osc and lin, though not always at the same time or together), but have NEVER done the sam's HV proceedure....I usually just put a probe on the HV turn the brightness to min, adjust HV to speck turn the brightness up and watch that the HV don't slump significantly before hitting the ragged high end of watchable brightness...That basically does the same thing only with less metering, and prep work.
If you are still confused feel free to ask me, and include readable pictures/scans of the horizontal section and procedure so I can be more speciffic.
EDIT: BTW there are often two slugs in an H. osc. coil (you will see 2 sets of ferrite core lines next to the ocs coil on the schematic if that is the case), and it can be necessary to use the diddle stick in your set that is narrower up the shaft from the hex part...That stick should be able to turn the top slug, but also to drop through it, turning the bottom slug independently when dropped through the top slug.
Old 12-15-2014, 02:45 PM
I'm going to get this one..
http://www.intertexelectronics.com/G...?ItemId=307531
Only a few bucks more and they are going to lower the $10 minimum.. I might as well get the better one..
Old 12-15-2014, 02:49 PM
Thanks Tom.. Very nice of you to do that.. I'm looking into a HV probe also.. I'll wait until everything arrives before attempting adjustments...
