Old 07-13-2017, 10:55 PM
Originally Posted by wa2ise View Post
I think he's talking about the red wires from what looks like the 1B3 rectifier tube socket (the brown plastic cylinder). One wire to the very high voltage GRT connection, and the other two a winding around the flyback core.
OK. You are correct about the 3 red wires.
Old 07-14-2017, 10:35 AM
DavGoodlin's Avatar
Motorola Minion
Originally Posted by Crist Rigott View Post
BTW, can anybody indentify the equipment in the shop as shown in the last picture of ALF?
I see an EICO Am signal generator behind Alf's right ear. The scope next is definitely not a common EICO 460, but the knobs look EICO-ish. Good stuff, usually in kit form. I assembled 4-5 of their kits, notably a 950B capacitor bridge checker, in continuous use since 1976.
-Dave G
Old 07-14-2017, 11:07 AM
I'm thinking Eico 465 for the scope, with An Eico signal tracer (147) to its left, and
a shortwave or c b radio to the right of Alfs head. The signal generator looks like an Eico 324.
Old 07-15-2017, 02:31 PM
OK, I've got the IF strip aligned. Now onto the 4.5MC trap adjustment. For this adjustment, they require a test "set up" or test detector. It requires a 4.5MC adjustable trap and some caps, resistor, and diode. Here are the pictures of the procedure and the test detector from Sams. Same thing in Riders.
Anybody have any tips on how to do this without the test detector? I don't have a 4.5MC adjustable coil. Unless I can pull one from a spare chassis?
Old 07-15-2017, 06:18 PM
I found a 4.5MC trap on an old Motorola TS-89 chassis and it worked out well.
Old 07-15-2017, 09:03 PM
Bill Cahill's Avatar
Super Moderator
Smile
Looks like you're coming along fine.
Please join my forum.
Old 07-15-2017, 09:47 PM
Thanks Bill.
I finished with the 4.5MC and audio alignment.
I installed the back and all that's left is to do is refurb the top knobs.
Old 07-15-2017, 10:39 PM
BEAUTIFUL! How did you de-yellow the back so well?
Old 07-15-2017, 10:42 PM
I painted it.
Old 07-18-2017, 02:09 AM
irext's Avatar
irext irext is offline
It's better than new!! Very nice.
Old 07-20-2017, 11:38 AM
Well, it is finished. Well almost. My buddy is looking for an antenna that goes into the handle. One of them has been pulled out. The other thing is I want to put some felt under the knobs on the top of the TV. Some before and after pictures.
Old 07-21-2017, 06:08 PM
decojoe67's Avatar
You do impeccable work! Very impressive. You turned that set into a real jewel.
Old 07-21-2017, 06:13 PM
Thank you.
Old 07-24-2017, 09:21 AM
DavGoodlin's Avatar
Motorola Minion
Nice job! The painting of the back cover really helps too. One of mine was painted gold, and still looks OK. The other is like yours.
My two should like this look as good!
-Dave G
Old 07-24-2017, 10:52 AM
If you don't find an antenna I have one. It's out of a slender seventeener but I think it's the same.
The plastic bushing is rough but the antenna itself is good.
yours for shipping if you need it.
