Old 04-16-2020, 04:43 PM
Originally Posted by kvflyer View Post
My thoughts, exactly!
+1
Despite the ringing that is very good picture quality for a 66 year old color TV. I'd probably decalre victory right there in your shoes.
Old 04-16-2020, 09:41 PM
The overall color looks great!
I do wonder if a re-tweak of the chroma bandpass alignment might make the transitions crisper, particularly, less of the blue phase distortion between the green and magenta bars. But, the IF alignment could get into the act here too, so it's a can of worms that might be better left closed. The effects are not obvious at all on the live video, which looks very good.
Old 04-24-2020, 02:54 PM
trinescope trinescope is offline
I have begun the process of stripping the old finish off the cabinet. The only real challenge is going to be the fake burl sections on the front doors. The finish is alligatored, and there is too much damage for these to be saved. The only options I can think of are using vinyl decals or installing actual veneer. Unfortunately I'm not so free at the moment to just walk into a woodworking store and have a look around. Any opinions on what would be best here?
As far as the electronics, I messed with the convergence adjustments again and got a bit better result overall. About the only thing left is cleaning the tuner so it stops acting intermittent. Everything else seems to be remaining stable. This set would never make a useful daily driver anyway (nor would I expect it to be) since the picture is dim and small compared to pretty much everything that came after, so as long as it looks and operates half decent I will be happy with it as it is.
Erich Loepke
Old 04-24-2020, 05:47 PM
My cabinet has real burl-wood. https://visions4netjournal.com/wp-co...B0997BE00.jpeg
If it was me, I’d stay away from decals. Nice image. May I ask the source? I’d like to try the image on my Westy.
Very good progress on your Westinghouse.
Old 04-24-2020, 06:12 PM
dtvmcdonald's Avatar
you mean the wreath? Its attached. The lower right magenta ornament
is hard to get right.
http://www.videokarma.org/attachment...1&d=1587769878
Old 04-24-2020, 06:16 PM
You beat me to it, the image was from this thread
http://www.videokarma.org/showthread.php?t=272376
My "burl" is definitely fake, I looked at it with a loupe and could see the halftone printing. I guess I'll go with real veneer if I can find some that is nice and flat.
Erich Loepke
Old 04-24-2020, 06:38 PM
Oh, you mean that you added the photo to a homemade video, played it on your set and took a screenshot? I can do that. I was thinking an actual video source.
Old 04-24-2020, 07:08 PM
Yes, I first took that image and added some areas on the sides to make it 640x480 then saved it to a USB drive. Then I used my digital converter box to display a still picture from that file. It's also how I do test patterns these days.
Erich Loepke
