Old 02-14-2022, 12:50 PM
It's possible the issue is a H-K short or bad H-K hum coupling in sweep or sync tube(s)...If a cathode voltage is hum modulated it would be harder to change it with B+ filtering than B+ hum.
Old 02-14-2022, 12:58 PM
Kevin Kuehn's Avatar
Workin' Late Again
Yet another thought are the caps bypassing the filaments to chassis ground. If any are shorted or leaky they could place AC on chassis ground which could in turn back feed into other circuits through their associated bypass caps. In other words the supposedly floating chassis could be at some AC modulating potential.
Old 02-14-2022, 01:44 PM
Thanks for the suggestions.
I've checked and rechecked the tubes for leakage. I could try swapping them all out.
This is a hot chassis set, not floating. There are a few ceramic caps along the filament string to the chassis but I'd expect they'd pop if they were leaky or shorted.
You can get the Sams for free here: https://www.earlytelevision.org/pdf/...sams_61-16.pdf
Old 02-14-2022, 02:05 PM
Workin' Late Again
The thing is that the picture is solid with the vertical sync referenced to the AC mains as with the BK analyst, so it could be inherent to the design of the set, and likely more of a problem with half wave voltage rectification. Possibly solid state diodes make in more so because they have such a low impedance.
[Edit] I just looked at what I assume is the correct schematic in Riders 3-2. The power supply is not what I was expecting.
Old 02-14-2022, 04:28 PM
A selenium, 6X5 and 25Z6 - what's surprising about that
Old 02-14-2022, 04:43 PM
Here it is in all its glory.
My favorite part is pin 4 of the 25Z6. It goes to a couple filter caps that have their negative going to the hot side of the AC line.
Then the hot (negative in this case) goes along with that rectified AC to power the self-contained HV generator.
Old 02-14-2022, 06:56 PM
This is the one you said has the "weird power supply" ?:P
Old 02-14-2022, 07:10 PM
dtvmcdonald's Avatar
Power supplies are not normally designed to intentionally explode caps
as this one appear to be.
Old 02-14-2022, 08:04 PM
Workin' Late Again
It's a different configuration voltage doubler than usual but I think the caps are correct polarity for that portion. What bothers me is the 12vpp ripple that you measured on the B++. More ordinary would be .5-1vpp? It looks to me that B++ only supplies the tuner, horizontal, and vertical oscillators, so it's surprising there's that much ripple.. something does not add up. I'd be tempted to break the line were B++ exits the cathode of the 6X5 and insert a current meter.
Old 02-14-2022, 08:43 PM
C5 and C6 appear to be backwards
Old 02-14-2022, 08:54 PM
Workin' Late Again
Ah. I was looking at Riders, which has those correct.
At any rate I think Bob found the smoking gun in an unsuspected area.
Old 02-14-2022, 08:56 PM
always where you least suspect
Old 02-14-2022, 09:24 PM
Yeah, this felt like an HK short issue all along. The one tube I never thought to test was the CRT
Old 02-14-2022, 09:31 PM
[url=https://flic.kr/p/2n3GguK]
OUCH!
finding another 7JP4 will be impossible.
risk trying to burn it clean or, use a separate transformer for it?
Old 02-14-2022, 09:36 PM
OUCH!
Bob's in Chicago within driving distance of me in Milwaukee...And I do have a spare good 7JP4...(heck I have the three amigos of 40s CRTs 7JP4, 10BP4, and 12LP4 sitting in my spare pile.)
