Old 01-30-2010, 01:12 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Yes, it's just a 12AU7. I foolishly bought the gold plated version of the ECC-82 from AES thinking that it would be more reliable and have better controlled characteristics if I had to replace it in the future.
JJ doesn't list this version on their web site anymore, which is interesting. AES still carries it.
I'm pretty sure the light bulb effect was because of a heater-cathode short. I looked at the schematic of the Precision 10-12 and when you set it up for a particular tube the first state that it will be in is with the filament return selected and all other pins connected to filament supply. With a cathode-heater short, say in the middle of the filament, then it's like applying 6.3VAC to a 3VAC filament. The cathode that is connected to pin 3 is shorted to the heater, but there's no way I could prove that it didn't happen after the burn-out.
I'm going to check the ECC-82 that I have in the vertical section with a leakage checker first.
Thanks for the offer of the 12AU7s. I just bought four "Baldwin Sylvania" 12AU7s on ebay for less than I paid for a gold ECC-82.
Old 01-30-2010, 08:26 PM
jeyurkon's Avatar
The ECC-82 was working even with the shorted heater/cathode because the cathode of that section is at DC ground anyhow. *I meant to also say that the filament supply is isolated.* It just injected some hum, which I had noticed. There had been a very small slow weave of the dot pattern. It would reduce the feedback in the horizontal oscillator a little bit.
I put in a 12AU7 that I had taken out of the set. It's at the low end of the good scale, nearly in the weak when I test it. Using it I get insufficient horizontal width and fold-over on the right. I hope the ones I ordered are strong.
I was surprised that it performed so poorly with this tube so I did some more checking. I found one resistor out of tolerance by 20%. It's a 10% resistor. Probably shouldn't matter too much but I'll replace it. Another one is off by 20% and one is just the wrong value. It looks like someone replaced it using the schematic from the previous production change and not the current one for this chassis. This ends up shifting the grid bias on the Horizontal Discharge half of the 12AU7.
The 6BD5 horizontal output tube seems strong and I didn't find anything wrong in that section.
Old 02-09-2010, 01:00 AM
jeyurkon's Avatar
Smile One step forward
I decided that R151, 470K being high by 20% shouldn't be problem since they used a 2.2meg in the previous version. I was wrong about R152 being the wrong value installed, I misread the bridge number in the schematic. R155 is a bit high, but again shouldn't cause a major problem. I tried various 12AU7's and still had the folding on the right. I decided to take the JJ ECC-82 from the vertical section and try it expecting to have the horizontal back the way it was. No, changer other than improved width.
I then did the horizontal alignment. This was much easier than the first time since there was much less interaction between the adjustments. Everything behaved as it should. I ended up with a nice horizontal alignment. This makes me believe even more that the brand new ECC-82 that I had used originally, had a heater/cathode short to begin with.
If you want to read about how the alignment is done you can find it at:
Service Manual
It uses the following supplements:
Supplement-1
Supplement-2
I have chassis C15 and bridge B17.
While the effects are obvious, I don't understand why the charge peaking resistor R211 needs to be shorted in the first part of the adjustment, or what the ringing coil L60 does.
An oddity is the 20MFD electrolytic paralleling a fuse. It's C219 around F1. Any ideas on that would be appreciated.
Old 02-09-2010, 01:15 AM
jeyurkon's Avatar
Unhappy Two steps back...
I was still having a problem with focus on the right hand side of the raster. Jr_tech's suggestion made the most sense so even though I didn't see a ripple in the screen bias I added, I decided to check it again.
I foolishly decided to try a different 6BD5GT HOT at the same time. I didn't get a raster and no HV. I checked the fuses and F3 was blown so no -125V.
I checked the 6BD5 I put in and it was at 100% where a NOS tube should be 70%. I probably should have reduced the horizontal width before turning it on. F3 used to be 1/4amp but they upped it to 0.3amps. Probably still marginal. Replacing it and going back to the first 6BD5 didn't bring back the HV though. I did all the tests I can without removing the HV assembly from the bridge and everything looks o.k. Fortunately the HV RF transformer seems good. That would really be unobtainium.
Maybe the 6Y6 went bad just by coincidence. Except for taking out the fuse, I don't see why the 6BD5 would make the HV go away. The heater of the 6W4 is isolated so a short there shouldn't matter either.
The radio works so the +170 and +180 must be o.k. I'll have to swap the 6Y6 and if that doesn't work, then start troubleshooting.
** I forgot, there was something else I did differently too. I had left the TV in the radio position when I shut the AC off. It was still in this position when I turned the AC back on. The HV section still has +170 and -125 supplied to it when the radio is on, but the filament of the 6Y6 is off. Maybe the 6Y6 didn't like waking up this way. Guess I'll find out when I sub it. **
Old 02-09-2010, 01:23 AM
jeyurkon's Avatar
My dad had cut 1/4" off the bottom of the molding in front of the TV section to make room for the cedar boards to fit. You can see the cut in the first photo.
I carefully measured the radius of the bead and bought a beading bit for my router. Although it's obvious in the second photo, I didn't notice that the step isn't perpendicular to a tangent of the arc. I could still use the router bit to make a replacement molding, but I'd have to do it in two steps. First make the bead at the appropriate angle, then go back and make another cut to square up the step. The second cut would have to be precise.
It turns out that the molding goes up 1/2" under the top front trim so all I really have to do is remove the molding and slide it down to the bottom. The top will still be hidden by the trim.
Well, if I break the second molding removing it I at least have a cutter to try to make a replacement.
Old 02-10-2010, 10:47 PM
jeyurkon's Avatar
Well, the lack of HV turned out to be the 6Y6. I put in a new one and I got a solid 11KV. Maybe there's something to this cathode stripping theory after all. I hope not, I like to listen to the radio on this set and that biases the 6Y6 with the heater off.
With the higher HV the horizontal width is marginal. I have to turn the width control to the end. I tried the NOS 6BD5 that I thought killed the B- supply. I turned the width to minimum first. It gave me a raster, then as I turned the width up it would soon start to collapse. Eventually, even at a reduced width bad things started to happen. I wasn't sure if it was Barkhausen or breakdown. It caused static in the audio and looked scary enough that I immediately shut it off. The tube tests at 100% when it should test 70% if new.
I can improve the width by going to a 6BQ6. It's an easy change, but it would make it a bridge code B18 instead of B17. I'm not sure if I want the bridge to be different than the version stamped on it.
This and the 12AU7 are two bad tubes in one lot from AES. I can't blame them, but the next time I order any tubes I'll test them in circuit immediately upon receipt. I have a small stock of bottle shaped 6Y6's. I have two really good ones from eBay. Looks like I'll need to obtain a few more.
The focus is better, but when using a dot pattern it's clear that it's an astigmatism. I can correct it with a weak external magnet. The next time I have the CRT out I'll try degaussing the yoke support and play around more with the location of the focus magnet. If that doesn't work I guess I'll resort to mounting a weak magnet.
The photo is the plate of the horizontal discharge 12AU7 tube. The service manual shows a rounded sawtooth and it doesn't have the dip between the teeth that mine shows. Is this a problem?
Old 02-11-2010, 03:21 PM
jeyurkon's Avatar
In regards to the scope trace of the horizontal discharge tube plate, it looks like the trace I show is correct and the service manual is wrong. Later sets using the same exact circuit show traces like the one that I photographed.
Also, C219 that is shown paralleling fuse F1 is partially explained by Wallace's Telaides. It seems to help the fuse respond only to the average DC current and not the large peaks from the horizontal sweep. Also, they moved one end from the +180 to the +170 to help the horizontal oscillator start more reliably. I didn't think a fuse had a significant impedance, but it must if this helps.
Old 02-11-2010, 03:28 PM
John Folsom's Avatar
John,
That Sylvania of yours is a very curious beast. Sylvania definitely did their own thing, design-wise. I have several 10" and larger sets that use RF high voltage power supplies, and have always enjoyed them. I have never seen any other 40s vintage TV with a large capacitor across a fuse. Seems curious, probably not the best design. But a really interesting set from a technical point of view. Thanks for posting the service data.
John Folsom
Old 02-11-2010, 08:55 PM
jeyurkon's Avatar
Originally Posted by John Folsom View Post
John,
Thanks John. To me the design seems straightforward because it's the first TV I was exposed to as a kid. I participated when my Dad did repairs, or when Gus Wall, our TV repair guy would make a home visit. And I actually enjoyed the smell of selenium rectifiers. Well, I admit the large cap across a fuse is strange..
From looking at old texts, data-sheets that I looked at nearly 50 years ago, and old magazines, I think Colonial Radio cut and pasted patented circuits and did some of their own weird stuff like the paralleled 5U4 and 7X6. The horizontal circuit seems to be from RCA. The RF HV, I'm pretty sure, is from Spellman who manufactured HV supplies for TV's. I think that's where they got their start.
Old 02-11-2010, 09:11 PM
jeyurkon's Avatar
6BD5 followup
I decided to try to understand why a 6BD5 that tested so good, performed so poorly. I guess if something seems to good to be true, it is.
The tube is definately NOS. The getter looks good at first glance, nice and shiny, but looks horrible when you shine light through it. I also noticed a slight haze on the envelope around the plate area.
So, I put it back on the tube tester and turned out the lights. When I did the dynamic test there was a blue glowing haze between the plate and cathode. The tube is gassy. It acts like it has higher emission, but is really gassy.
The supplier only gives a 10 day warranty period and I tend to be too trusting. I'm dissappointed that I had two bad tubes in one order. I've had better luck with eBay. I'll still use them but I'll test as soon as I receive any tubes and I have a better idea of what to look for now. Hopefully I won't fool myself like I did with the gassy tube.
I have a Senecore LC3 leakage tester which works great for the tubes it handles, but it doesn't do the 6BD5 or 6Y6. The Precision 10-12 will find shorts, but doesn't do a sensitive leak test. But I have seen 1B3's glow blue from gas with it and now the 6BD5.
I'm tempted to try a 6AU6, would that make a good substitute for a 6BD5?
Old 02-11-2010, 10:17 PM
"I'm tempted to try a 6AU6, would that make a good substitute for a 6BD5?"
huh?
Oh, I get it... My substitution book sez 6AU5 6AV5 6FW5 if not series filament circuit.
Old 02-11-2010, 11:03 PM
jeyurkon's Avatar
huh?
Oops! Typo. The filaments are all parallel so there's no problem there.
Actually I wasn't wearing my glasses and a 5 looks alot like a 6 when it's smeared out... Thanks for pointing that out.
Old 02-16-2010, 01:18 AM
jeyurkon's Avatar
The 12LP4 that Scotty has rebuilt with a rebuilt gun came today. I installed it and it works great! I still have to figure out the focus issue though.
I might have to go back to the 10MP4 just to make sure that something else didn't change or fail coincidentally.
Old 02-16-2010, 01:43 AM
Awesome - I'm glad someone is still rebuilding CRTs!
Old 02-21-2010, 09:50 PM
jeyurkon's Avatar
Still trying to figure out the focus issue on the right side. I tried rotating the focalizer 180 degs but that had no effect. I thought that if it was at fault that the problem would switch to the left side.
I scoped all the voltages including the HV. They're stable. Only the HV shows any structure and I don't believe it's enough to cause the problem.
All the photos have a vertical scale sensitivity of about 60V/div. It was AC coupled using a 20KVDC, max pulse 40KV scope probe.
In the first photo you see the pips correspond to the horizontal retrace. The rest of the variation is due to the video signal. The second photo has the time base set to view the vertical sweep period and the fuzz is the horizontal retrace pips. In the last photo I turned the brightness down and all you see are the horizontal pips.
I think the horizontal pips are capacitively coupled from the windings on the yoke to the aquadaq, which is capacitively coupled to the dag on the inside connected to the HV. The horizontal windings are closest to the neck of the CRT.
The HV was about 11KV during this test. The variation appears to be about 50 volts PP. I doubt that 50 volts would affect the focus much.
The resistor in series with the HV supply is about 470K. So, 50 volts means about 100 micro-amps, which is probably reasonable with the brightness set high.
I looked at the old test pattern photos I took with the 10MP4 and I see that it has the same problem, just to a lesser degree. I'm starting to think that the problem is with the yoke.
I'm going to ring test the yoke and perhaps swap the horizontal leads to see if the focus issue moves to the other side of the screen or stays put.
