Old 02-01-2011, 10:34 AM
Tomcomm's Avatar
Tomcomm Tomcomm is offline
HOT Current vs Fuse Current #2
I am now using a 22mf electro across the analog VOM for HOT current measurements. I corrected the posting where I measured 128ma using a DVM. It now reads 180ma at both Hot cathode and at the HV fuse. Seems reasonable since current in is current out in these simple circuits. Ultor / HV reg current only amounts to a 1 or 2ma difference if you want to be nit picking.
Old 02-01-2011, 05:45 PM
miniman82's Avatar
First Light: 1952-2011
Glad to hear I was right.
Evolution...
Old 02-01-2011, 05:56 PM
sampson159's Avatar
sampson159
glad to hear that tom got his set performing properly.thats what we are glad about
Old 02-01-2011, 06:25 PM
miniman82's Avatar
My pet peeve is misinformation, sorry if that anoys some of you.
Evolution...
Old 02-01-2011, 07:59 PM
sampson159's Avatar
sampson159
i am sure the "misinformation"wasnt purposely intended to peeve you.i find tom s posts very informative,well written and enlightening.no competition here in this forum.some of us are still learning,others teach and then there is the one who knows everything.i am still learning and glad to associate with these fine fellows.
i personally dont have a pet peeve.just realize everybody has different looks,tastes,actions,etc.can you imagine a forum where everybody was the same?how would you like to talk with people just like you?it would get boring very quickly.as a matter of fact,i am bored with this post.goodnight
Old 02-01-2011, 08:12 PM
AUdubon5425's Avatar
Don't get mad - get GLAD.
AUdubon5425 Youtube Channel
Old 02-08-2011, 07:51 PM
Tomcomm's Avatar
FBX Setup is OK
I just made a major capital equipment purchase, a Heathkit HV Probe for $39 including shipping. When used with my 1950 Heathkit VTVM I was finally able to setup my 6BK4 HV reg after I cleaned the 66m resistor with lacquer thinner. It was reading 24m with 50 years of crud on its body. Now the ultor is held at the desired 27KV constant at all brightness levels. Some important readings:
At ac in of 115vac, B++ is 424v, horz system current at fuse is only 172ma (same as HOT cathode), boost is 725v, focus is 5.5kv, Ultor is 27KV. After > 2 hours operation, the FBX primary and HV doughnut were barely "body temp", < 110F!
The last major effort will be the horz dynamic convergence system. The latest pics are with only vert convergence:
Old 02-09-2011, 02:34 AM
WA3WLJ's Avatar
WA3WLJ WA3WLJ is offline
Glad 4 ur success
GLAD 4 UR SUCCESS
Old 02-09-2011, 11:56 AM
Kevin Kuehn's Avatar
Workin' Late Again
Those screen shots look pretty good to me.
Dummy question here: What's the reason that HOT circuits typically don't incorporate some type of current regulation circuitry? The way I understand it, is that if you loose Horizontal drive, you end up with a melt down.
Kevin
Old 02-09-2011, 12:34 PM
trojanrabbit trojanrabbit is offline
My attempt at a dummy answer--
Seems to me that the tuning of the HOT / flyback is already delicate enough under good circumstances. Adding another circuit or two for protection in the case of complete horizontal drive failure might have made the whole thing even more unreliable.
How often were there cases of complete horizontal drive failure?
Easy enough to do in the IC age (and they were probably more concerned with keeping HV/x-rays under control than protecting any circuitry)
Old 02-09-2011, 12:50 PM
Workin' Late Again
Maybe I should have stated current limiting instead of regulation. Probably wasn't a threat back in the day when OEM parts were available. But I've heard horror stories of very early paper coupling capacitor failures on mid 50's sets.
Kevin
Old 02-09-2011, 02:54 PM
Kevin
The simple answer is that anything more sophisticated than a fuse would have been way too expensive with tube technology - the simplest current comparison circuit would require at least one more tube stage. Safety shut downs became affordable with the use of transistors, and eminently affordable with ICs. Even then, there were cases of tolerance issues causing unnecessary shutdowns sometimes. With the wide tolerances on consumer tube circuits, this would have reached intolerable false failure rates.
Old 02-09-2011, 04:40 PM
Workin' Late Again
I suppose if the HOT was self-biased, then it would not provide a large enough current spike as required. Are those running something like a class C TX output?
Kevin
Old 02-09-2011, 10:08 PM
Kevin
The HOT under normal operation is either on hard, so the voltage across it is low when current is flowing; or it is completely off, so the current is zero while the voltage is high. Therefore , the power dissipated is low, because the product of (voltage x current) is low or zero. Without the drive waveform, it can be somewhere in between - this condition of having both current and voltage means that the power dissipated in the HOT goes up drastically.
Old 02-09-2011, 10:16 PM
rca2000's Avatar
rca2000 rca2000 is offline
So, another way to describe the HOT ckt would be like a "switching power supply", I reckon, and class "C" is not too far off.
As we know, in an SMPS, the switch transistors must be on or off, and nOT much in between..or WAY too much current--and then destruction--immediately follows.
