Old 06-19-2011, 07:39 PM
Huh. By golly that tube does not have an external aquadag coating. That wire around the HV lead has no electrical function, it's just a mechanical support.
At least you've located what's doing the arcy sparky thing.
oc
Old 06-19-2011, 07:40 PM
It doesn't look to me like your CRT has any aquadag coating on it - not all do. I bet there's a high voltage capacitor next the the rectifier tube that does the filtering.
The arcing could be caused by component leads or wires coming too close to the base. I recently worked on a Motoorla that had bad arcing caused my a wire coming too close to the rectifier. All I had to do was move it out of the way.
Did you do any work around that area ?
Old 06-19-2011, 07:47 PM
xxxxxxxxxxxxxxxx
Last edited by roundscreen; 06-19-2011 at 07:48 PM. Reason: Some one noticed it before I did
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
I did not. I'm almost positive that the arcing is happening inside the tube itself. I'll fire the set up one more time and be sure.
Old 06-19-2011, 07:48 PM
vts1134's Avatar
Looking For Time
Originally Posted by roundscreen View Post
Did they make a set with a glass crt that did not have a ground going to the chassis? Is there a door knob cap connected to the HV rectifier? If not I think you may have washed off the aquadag coating when you cleaned the crt.
From what I see in your pictures I do not see the aquadag coating.
Ed
There is a door knob cap at the base of the HV rectifier.
Old 06-19-2011, 07:52 PM
That is the first time I have seen a set with a glass crt that did not have a aquadag coating on it.
Ed
Old 06-19-2011, 08:23 PM
vts1134's Avatar
Looking For Time
The arcing is coming from inside the tube, I'm sure of it now. The picture is kind of hard to see because the room was dark but you can see the bluish glow coming from inside the 1X2. Am I right in assuming that this tube is no good?
Old 06-19-2011, 08:29 PM
miniman82's Avatar
First Light: 1952-2011
Yep, it has air in it and the HV is causing it to ionize. Replace it, and get that HV all the way to the screen!
Evolution...
Old 06-19-2011, 08:39 PM
Ed
I have several early rectangular 16" CRTs with no coating on them. I'm not sure why though. The datasheets state that they should.
Old 06-19-2011, 10:17 PM
That is interesting. Do your set's have a door knob cap connected to the hv rectifier tube? In A set with a metal cone crt the door knob cap goes to ground.
Wonder why are they using a door knob cap in a set with a glass crt instead of using the aquadag for a path to ground?
Ed
Old 06-19-2011, 10:38 PM
Ed
Yes, they have doorknob caps. So do most of my 10BP4 and 12LP4 sets with grounded aquadag. I guess they wanted the extra capacitance. I think only my cheapo Motorolas rely entirely on the aquadag for HV filtering.
Old 06-20-2011, 05:23 PM
vts1134's Avatar
Looking For Time
Got a new 1X2 today but noticed that the old 1X2 was a 1X2A and the new one is a 1X2B. The old tube is on the left and the new tube is on the right. Are these interchangeable?
Here is the new tube installed and waiting for a higher intellect to give it the green light.
Old 06-20-2011, 06:36 PM
VintagePC's Avatar
Tube bug got me 05/2010
Yep, they should be interchangeable.
Take a look at the letter code specifications - the trailing letters indicate features of the tube. A/B/C are revisions that are backwards compatible, and there are a few others like GT, M etc. indicating glass tube, metal, and some other things.
http://en.wikipedia.org/wiki/RETMA_tube_designation
Old 06-20-2011, 07:13 PM
vts1134's Avatar
Looking For Time
Fired the set up and got this.
Fired her down immediately. Is this normal? Just a burn off process or a symptom of another problem?
Old 06-20-2011, 07:34 PM
Holy mackrel. Possibly a dead short either in the doorknob cap or from the 1X2 filament winding to ground. oc
