Old 03-18-2013, 08:26 AM
Geist Geist is offline
Hi All;
I got some of the Caps on saturaday.. If I don't have to go to work, I will take out the 10K resistor and put it back as per origional, along with changing out the .05 caps..
THANK YOU Marty
Old 03-18-2013, 11:26 AM
Hi All;
I have started to change out the caps..
I have also noticed, that my 630 is an early Version.. On the three terminals on the back, mine has two caps and a resistor, for the Sync modification, where as the 8TS30 has the one Cap in the 1st Video section.. Also on the Sams there is a Tie on point for a couple of Caps that I don't have.. I am not saying that they don't exist, but they are wired somewhere else.. I am also going to check that the compensating cap for the 1st Video and see if it is in the circuit..
THANK YOU Marty
Old 03-18-2013, 12:12 PM
well ive been there and there is alot of those caps so be real careful replacing them, one at a time. i have a 1947 fada that uses the same chassis and i changed every cap except the domino micas, but did replace a verticle mica cap for the timing as well as another i think it was around the 6sn7 tube for the horizontal. and of course the electrolytics. i did place 2 caps in the wrong place at the 6sn7 and ultimately because of probing to find out what i have done as far as a mistake i burned the power transformer out. but i found a nos for 60.00 put it in look for my mistake fixed it and this set today works like new. so dont do what i have done, take your time its worth it in the end.
Old 03-18-2013, 01:09 PM
Hi All;
Timmy, I plan on doing a few caps at a time, then testing it.. Before going to the next group of caps.. Hopefully, It will make finding mistakes alot easier..
THANK YOU Marty
Old 03-18-2013, 03:29 PM
oh just keep in mind that when you clip one and turn for a moment and dont remember what end goes where then its trouble but if you have the sams like i have then it makes it easy if things go wrong and you supect you maybe put something somewhere else by accident. in my case what happened was my daughter was asking me something and this triggered what happened to me with 2 caps being put in the wrong place which had to do with horizontal frequency and a blue glowing hot. this drove me nuts but i looked back on the sams and wow there it was. good luck with the 630
Old 03-18-2013, 04:00 PM
Hi All;
Timmy, Thanks for the warning.. My biggest problem with the Sams is since mine is a copy, and my eyesight isn't that great, I have trouble seeing those little details.. Like where wires go or are attached..
I have an 8TS30, that I use for comparison and the Ryders..
This set didn't have any compensation Cap on the 1st Video Amp, so I took it from the 830.. I am just about to try it for the second time today.. I have 6 (each) .047 Caps done as of now..
Its a little better each time I try it.. Still has smearing issues.. But I can make it lock and unlock , (I think) in both Vertical and Horizontal.. Its possible in the sync sections or still in the video sections.. I have some other Caps on order and they will not be here for a week or so..
THANK YOU Marty
Old 03-18-2013, 04:35 PM
Hi All;
This is the longest that the set has been on !!
I put a Video signal on the connector on the back, part of the Horiz. Sync Discrimiter.. I origionally thought it was part of the Sync Amp.. And I got some picture .. Its a mess, but it is Video !!!
I need most likely to replace the Sync Integrator Caps and Resistors, when they come in from Mouser.. I will look at the 1st and 2nd Sync Amps and the Sync Seperator and see If there is any other Caps that I have at the present that I can replace now..
THANK YOU Marty
Old 03-18-2013, 04:42 PM
By golly sounds like she's gettin' there. It might be s good idea, especially when replacing resistors, to power the set up after each replacement. If a resistor happened to be off value by a single decimal place, it can really throw you for a loop if you don't catch it right away.
Old 03-18-2013, 04:46 PM
the sync loc i think has 1 or 2 caps right off that unit. and its not a good idea to touch the adj on the inside of the chassis of the sync loc because there are 2 adj , outside and one inside.
Old 03-18-2013, 05:17 PM
Hi All;
Timmy, I am not even thinking of much in adjustments yet.. Too many other issues, that have to be resolved before I get even close to that point.. Thank You Old Coot, I would have not thought of that being an issue..
THANK YOU Marty
Old 03-20-2013, 02:28 PM
Hi All;
I am now a firm believer in doing a few caps at a time.. I just did a few put it all back together and No Picture.. Took things like picture tube out and turned the chassis over, and after comparing my two sets I found my wiring mistake.. I fixed it and tried the Set again, and I have a Picture Back..
And If you have the capability having two similiar sets, Helps alot also.. Doing an A to B comparison, pointed out the mistake real fast..
THANK YOU Marty
Old 03-21-2013, 02:15 PM
Hi All;
I have all the Caps in that I currently can replace.. The next batch should come in early next week.. When I can do the rest of them.. At present the picture is kind of folded over.. But, untill I can get the rest done, I can't do any real in depth analysis.. I am glad that I have anything on the screen for now.. I figure some picture is better than No picture..
THANK YOU Marty
Old 03-21-2013, 05:04 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
I'm looking forward to final pictures of this restoration. Keep up the good work Marty
Old 03-22-2013, 04:25 PM
Hi All;
I got the Caps in, I didn't expect them till the middle of next week.. The TV is put away for awhile, and the kitchen Table has the Stepper on it at present.. I can't put both on the Kitchen table.. I just Reprinted up an 1" and a quarter of Documents and old emails, that I need to re-read to get back up to speed with it.. I couldn't find the papers from before..
This will give me a small Break from the TV, so when I go back to it.. It will be like all fresh and new and a renewed perspective on it.. Which can make me notice things I didn't see before..
I wish those of you that are interested in either the TV or the Stepper, lived closer, so I could explain my thinking in person, while working on something, and we could both be actually looking at it..
THANK YOU Marty
Old 05-09-2013, 04:07 PM
Hi All;
I have brought back the 630 from the Back room, and put the Stepper away for now.. The Kitchen Table has room for only one or the other, but not both..
I have more caps to replace.. And can start testing parts of the 630 once I have replace more of the caps..
THANK YOU Marty
