Old 05-06-2018, 01:57 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
With an interference engine, isn't there more damage to the engine than the just the head and valves? Possible damage to the piston faces or block.
In my experience, VERY rarely. Most typically, two or so cylinder's valves just get bent aside (effectively making them stuck open), and maybe put a tiny ding on the top of the corresponding pistons. I think I may have seen one engine that had a hole poked in the piston, out of the countless broken timing belts I've seen. Long story short, if it's a fight between a piston and a valve, the piston wins.
Old 05-07-2018, 11:00 AM
I saw the former Kia owner Sunday, but forgot to ask him if he pulled the head to see how much damage was done to the original engine.
He pretty well knows his way around cars, but this winter seemed so long and cold, so who could blame him.
Old 05-07-2018, 12:30 PM
maxhifi's Avatar
maxhifi maxhifi is offline
Hmm, I've seen cars written off (by their owners) for this, when there was plenty of value left in the rest of the car. Maybe a good way to get a cheap car, if there's a little luck involved!
I guess it's becoming less relevant, with the industry moving away from timing belts. The main problem is how darn annoying front wheel drive cars are to work on.. I had the timing belt off in my RWD pickup in a few hours.
Old 05-08-2018, 02:40 AM
MadMan's Avatar
The Resident Brony
You might get lucky sometimes. I've been the own who's written off a lot of those cars. It's still a big expensive job, the head being at the machinist's is about $400 by itself, then all the R&R at a decent shop is another $600-$1000. So yeah, depends on the car's value.
Oh yes... much less relevant. Now more cars are using timing chains... riding on plastic guides that become brittle in the heat and oil of an engine by 100k miles and break and destroy the valves just like a broken timing belt. I've already dealt with several of those. In general, they're much more labor intensive. You're honestly better off with a rubber belt. You'll have to do the maintenance either way, and a belt is typically easier. I suppose the one advantage a chain design has is the absence of camshaft oil seals.
On occasion I've been able to do a chain job preventatively. It's hard to catch though, because it's not as easy as just peeking behind a plastic cover to look at the condition of a belt. :/ It's also not a 'recommended' maintenance, nor is it something the ordinary motorist (or indeed, mechanic) would even consider to be a maintenance item.
Old 05-08-2018, 02:02 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
Thats my "case" for timing belts, at least for OHC applications. as for front wheel drive, that's why I'm in a Miata right now. the timing belt shouldn't be too hard on that one, it was replaced at 80k, and isn't due until 160K.......unless the water pump craps out.
Old 05-09-2018, 01:11 AM
MadMan's Avatar
The Resident Brony
Oh it shouldn't be too bad. But I would do it at 140k or earlier. In fact, most manufacturers recommend a shorter interval after the first belt. It's typical for it to say at 120k then every 60k afterwards, for example.
Old 05-09-2018, 02:40 AM
mgross0 mgross0 is offline
Mopar typically recommends a timing belt change every 90k or ten years. The average 3.5L will need five timing belt changes during it's lifetime, if you take care of it. Of course I should also mention that it may need seven tranny changes, depending on the model year. UltraDrive could be a real stinker, especially if you used the wrong fluid.
Old 05-09-2018, 10:21 PM
dishdude's Avatar
dishdude dishdude is offline
I suspect a lot of people were sold transmissions that only needed a sensor or solenoid pack too.
Old 05-10-2018, 01:34 AM
MadMan's Avatar
The Resident Brony
Yeah, the Ultradrive aka A604 is actually a really solid little transmission. They don't even make Dexron 2 anymore, so you'd have to be a special level of incompetent to screw it up these days. And sure they have their problems, but so does literally everything else.
Old 05-10-2018, 10:09 AM
maxhifi's Avatar
The Miata is a non-interferance engine, so if the belt does break, it won't be a total disaster.
Old 05-10-2018, 10:15 AM
maxhifi's Avatar
Any brands/engines specifically prone to failure? I've seen plenty last a lot longer than 100k, miles, but if that failure prone it sounds like gambling.
Sounds like a reasonable case for pushrods, that style of engine lasted great, no fancy cam drive system..
Old 05-10-2018, 01:16 PM
DavGoodlin's Avatar
Motorola Minion
St
Has anyone mentioned the original timing chain fail when General Motors used nylon timing gears on their very-interfering small-block V8. Not to be outdone, they used the softened camshafts later in the 70's that rounded lobes by 60K miles.
-Dave G
Old 05-11-2018, 12:43 AM
MadMan's Avatar
The Resident Brony
Most are still a bit new for me to start pointing fingers. Of some of the older ones that I've personally seen... VW's 2.8 VR6 (doing one atm), Ford's 4.0 v6 (Explorers, mostly the older ones [enormous pain in the ass to do]), MINI's 1.8(?) (was able to catch that one early), GM's Ecotec 4 banger (saw one go at 60k, another at 100k [strangely I've only seen it in 2010+, design change, maybe?])... and that's all that's coming to mind atm.
NICE!
Old 05-11-2018, 10:33 AM
NICE!
I had a 2001 Ford Explorer that had the 4.0 V6. When it was started from cold, the engine would rumble until the oil pressure came up, but only for a few seconds. It seemed to run alright, but I traded it at 120K when it need front end work and tires. I thought if I did the rest of the work and the engine failed, it was a big expense.
I traded it on my 2005 diesel Jeep Liberty which was totaled in Dec. 2009 in a freak accident.
Old 05-11-2018, 10:43 AM
St
I heard of a couple of owners that had major problems with their Garbage Motors engines with low miles on them and well cared for.
What did they do! Bought another GM product! Gluttons for Punishment!
