Old 05-05-2024, 10:38 AM
vol.2's Avatar
vol.2 vol.2 is offline
Originally Posted by luRaichu View Post
Please, enlighten me to any other repair shops or techs in Maryland or Virginia. I cannot bring myself to work on this set anymore.
Honestly, no. I don't know of anyone I can fully recommend. Danco is a great tech, and he won't rip you off, but he is retired and doesn't care about taking jobs unless they are interesting to him, and he has told me on numerous occasions that he especially doesn't like taking in jobs that other people have been messing with.
There's no one I'm aware of in Maryland that will take in a CRT and can be trusted other than him (if he will do it), and I don't think he's too likely to touch yours, and if he did you would be paying out the nose for it because he charges hourly and his time is valuable.
There used to be a LOT of guys in the area who would do it, but they all retired and/or died like 20 years ago. Danco was a late arrival, and then he made most of his living handling all the audio/visual equipment for the National Zoo, and doing big important restoration jobs for museums and stuff like that, so he could afford to keep the small neighborhood shop running.
I think you're going to have to look in Northern VA, there's a much better chance of finding someone over there.
But seriously, this particular TV you are working on isn't worth what someone competent is going to charge you. You could easily be looking at over $100/hour for that kind of thing, and it's a basket case.
My advice is to keep cracking at it, or let it go. And that doesn't have to mean getting rid of it; you can mothball it and get back to it after you have more experience.
Also, you might want to give some thought to getting some better equipment if you want to mess with this stuff more. At the very minimum, an isolation transformer is really important as a safety precaution. Without one, your line leads are connected directly to the grid on the neutral
Old 05-05-2024, 06:03 PM
luRaichu's Avatar
luRaichu luRaichu is offline
NIGHT STALKER
I think it's worth it. Almost nobody has these CT-1310s anymore (Well, my neighbor did, until I showed up a month ago). We'll just have to see what Shipley's says. After all, they appear to have rave reviews and are still in service.
If I must continue working on this set, the way forward would probably be replacing transistors and diodes. After all, the HOT is a big transistor & was blown when I first got this set (which is why it'd been thrown out).
We're all in the same boat.
Old 05-05-2024, 10:56 PM
Retired Batwings Tech
So what makes this set so valuable?
Old 05-06-2024, 01:06 PM
luRaichu's Avatar
NIGHT STALKER
I just called up a bunch of shops and techs in Maryland and nobody in the area can or will work on my Panasonic set. I guess I'm still on my own here!
So, how should I test, order, and replace bad diodes/transistors in the PSU/Horizontal circuits? Those are the only problem I can think of.
Old 05-07-2024, 12:38 AM
[QUOTE=luRaichu;3257145]I just called up a bunch of shops and techs in Maryland and nobody in the area can or will work on my Panasonic set.
This doesn't surprise me really, the number of "TV-Radio" repair shops remaining are but a small fraction of what they were a quarter century ago. Most of those techs are retired or have become silent and the few that are around know little to nothing of the legacy technology. I grew up in TV shops having them in the extended family, both had closed up by the mid-90's because the business dried up.
So what to do about your ailing Panasonic Color Pilot:
If it was me I'd go back over my work again after a short break, say a week or more to get it out of my head.
Starting over with in-circuit checks of transistors knowing the junction is about 0.75 volts, I use a Fluke model 77 DVM that I've had since the mid-80's and it has a real diode check function that shows the actual junction conduction voltage. Okay so the semiconductors all show the correct forward drop in their respective directions I then move on to capacitors. You said that you have replaced a majority of electrolytics, what did you use? This is very important as the vast majority of chinesiums are bad right out of the box. When I say bad I mean internal current leakages and high ESR values. More often than not I will use salvaged capacitors out of the last generation surround receivers that had worked but replaced for an "upgrade" and these salvaged units are performing well. One of my present 16:9 monitors is a Panasonic CT34WX54 widescreen CRT that is presently running salvaged electrolytics along with ALL of my Sony PVM-5300 triple monitors I use for production work. 1984 vintage take-outs from the local FOX affiliate with millions of hours they got recapped with salvaged caps and work as they should. Have you gone over the top of the board and actually verified each capacitor is the proper value according to the schematic AND the polarity is correct?
Okay so we "think" the electrolytics are good being name brand parts like Nichicon then I'd move into the various supply voltages following the schematic. With the horizontal transistor blown I'd remove it from the circuit and sub in a 40-watt incandescent lightbulb between the emitter & collector to load the main part of the power supply, no you won't have any sweep but this is not important at the moment... an oscilloscope however would be most helpful and the reason for this is even without the HOT in place there should still be drive available on the collector of Q501 unless the failsafe has an issue. Without horizontal pulses coming into the failsafe it shouldn't trigger a shutdown. How about voltages? We don't need exact numbers here, +/-5% is a good working margin. That being said what are the voltages going on the various circuitrace flags listed on the schematic? If they're within the spec tolerance how about at the various collectors of transistors or the VCC point of IC301? I've been trying to follow along the schematic you posted the image of but the hosting site is a pain and I can't see the whole thing.
The problem here unfortunately is a lot of variables have been added and it's become a circle of tail chasing with the only solid result being shorted horizontal output transistors and frustration. Replacing capacitors was a necessity, you pulled one that was missing a lead that had corroded away however without the necessary test equipment you're still trouble shooting from the hip.
Those flybacks have been known to short & fail, the ones I've experienced won't even run long enough to light up the screen but that's not to say it couldn't while eating expensive transistors along the way.
I've been going through all of your posts trying to put together a summary of what has been accomplished to this point. Electrolytics replaced, resistors tested and a complete resolder. This is the one that I'd focus on first, with a magnifying glass and lots of time. All it takes is a bridged pair of pins on an IC or between two close spaced leads to throw everything into a tailspin. Have you carefully done a visual on the board and I mean out of the chassis? Don't like the smell of flux? Sorry but it's a fact of electronics repair and you will have to deal with it. Personally I'd pull the board completely and do a de-flux using the fuel additive "Purex99" in the red bottle, that is 99% pure isopropyl alcohol and that will take ALL the flux off with a little scrubbing with an old toothbrush. From there I would be looking at every connection following the traces around and giving attention to the closely spaced leads for any sign of a bridge. This can take some time... a lot of time. I'm also seeing a lot of frustration and impatience, I pick up on these things. It's this frustration and impatience that makes a big pile of smoked parts.
What I can't do is fix this over the internet despite my past experience with them, until I actually get my hands in something and a feel for what's going on all the explaining in the world is not going to help, this is why I say to go back on all of your work starting with fresh eyes after taking some time away from it.
Options and I'm being serious here. One is you could keep at it and take things step-by-step. Two is finding a someone willing to work on the set but that sorta defeats the prupose doesn't it? I mean you fixed a McIntosh right? Three is you could box it up and donate it to me so I can fix it and add it to my collection saving the remaining horizontal output transistors of the world from certain destruction. I'd even pay the shipping.
Old 05-08-2024, 12:21 PM
luRaichu's Avatar
NIGHT STALKER
I used mostly Würth Elektronik & a few Nichicon caps. I would never trust the cheaper brands like "Elite".
I couldn't cross-reference with the Sams' as I don't have all pages; but I've checked and every new cap installed is the exact same capacitance, same voltage rating or higher as it's predeccessor. Polarity is easy because most if not all caps on the main board have their negative side facing right.
As you might have seen, I measured and re-measured the PSU voltages prior to the +B regulator taking a nose dive. Everything seemed up to spec then.
Also, I agree, an oscilloscope would be useful at this point. Perhaps I'll look into getting one. But I think the 100 watt lightbulb in the post-recap +B circuit overloaded the PSU or something else, and caused damage. That's why I somewhat suspect burnt resistors, diodes, and transistors as they may have had their power rating exceeded by the bulb's current draw.
I tried running with a much smaller 15 watt bulb in place of the +B fuse but the set wouldn't power up this way. Only a feeble whine. After I removed the bulb, that's when +B started floating around low.
Good call. I will check this.
You can download them from the hosting site and magnify with your image viewer of choice. If not I can put the schematics up on the Internet Archive and you may see them better there.
It's only the OLD flux that really smells like shit. I've always been fine with it though, but my neighbors sure aren't.
Couldn't you use the 90% alcohol they sell at drug stores?
Yes, but all that'd brought it back from the dead was a complete and utter recap. Despite this I couldn't save the floppy drive & ye olde spinny hard drive soon died from goopy head bumpers.
Also this was one of the cheapo, "pizza box" form factor Macs. They weren't the early compact ones with a 9" CRT built-in, you had to source your own monitor for these.
Old 05-08-2024, 06:38 PM
vol.2's Avatar
An oscilloscope yes, but also a an isolation transformer. That will greatly reduce the chance of a fatal accident if you touch the wrong thing
this is just about the cheapest scope you could get any use out of. You still can't do high voltage without differential probes, but you would need to buy those separately with more expensive scopes as well
also, get yourself one of these types of devices to do a quick check on diodes and transistors. It's not completely foolproof, but I find they generally don't lie, and they will almost certainly tell you if a transistor is still showing as one or not. Capacitance is also fairly accurate up to a certain point. I think they start to get so-so around 2200uf and up
I'm not specifically endorsing either of these two devices or sellers; there are many versions of them on amazon and ebay, and they are all pretty much the same thing AFAIK. Just read feedback and stuff and find a good deal on a good one
Old 05-11-2024, 03:01 PM
luRaichu's Avatar
NIGHT STALKER
Can't power on the set yet so here are pictures of the mainboard I took today. Feel free to pour over them, I cannot see anything wrong myself.
To get the full-resolution photos please download from imgbb.
Note: C605 appears bridged in the first photo, but it is not.
When doing the first solder reflow, I noticed C751 was bridged. I don't know how long it was bridged for. Since then, C751 has been replaced but to no improvement.
The horizontal driver section may've been pooched by the C751 short, now that I think of it. Should check waveforms.
Old 05-12-2024, 09:14 PM
vol.2's Avatar
Doesn't appear to be broken to me. A couple of notes.
1) that resistor on the back of the PCB is somewhat sus. i've had issues with those plastic package resistors before. maybe it's fine, but could be worth testing them if there are any others on the front side. the one bodged onto the back is unlikely to make a huge difference anyway, but if there's one, many there's others
2) there's one spot towards the bottom that i don't understand. it looks like missing solder on a connector or something, but perhaps that is supposed to be that way?
this:
Old 05-13-2024, 09:05 AM
JohnCT's Avatar
JohnCT JohnCT is offline
Did they miss the renaissance or what?
In the mid 90s, I made a fortune servicing RPTVs and even tons of CRT TVs like the RCA CTC17X series as I was an ASC for Thomson. I was doing between 5-10 CTC 175/6/7s a day. I knew them so well I didn't even look at them before calling the customer to give them an estimate (I pretty much flat rated them based on screen size). Most were corrupt eeproms from bad grounds on the tuner shield, horiz output, and regulator output heatsinks. A few flys here and there but the flybacks were pretty cheap.
On rear projection TVs, most problems with Japanese brands were convergence related and I used to buy STK modules a hundred at a shot.
The RCA rear projectors didn't have convergence problems (all discrete components) but the guts were built in a crate - two brackets and two unplug harness and the box was out of the TV and in the truck in 5 minutes. Most RCA projection problems were smps rebuilds or HV splitter boxes.
Good days.
Old 05-13-2024, 10:42 AM
At that time I wasn't interested in lugging the brutes around and they were looking to retire, I remember hauling a few of those big 30+ inch CRT's to the bench but never got into the RPTV's. I miss the days of the EZ triplers and sagging 3A3 heaters that took out the flyback.
Getting back to the Panasonic I see so many suspect connections I don't know where to start but D551 anode is just as good as any. First soldering takes a lot more than globbing it on the connections and hoping it conducts, they need to be heated until the solder flows. Those connections on the flyback are not up to par by any means. I see the majority of solder connections have not been touched and they are all suspect until addressed. Soldering is a skill that comes with years of practice, not something you can learn from a book. Honestly I think you bit off more than you can chew with this one.
And this is what separates the experienced. just a quick glance I see a halo around the anode of D551, the posts around the DY terminals esp #3 don't look very good. TPB4 looks to be shorting across to the adjacent trace for TPB3 just above R603. All of the connections around the flyback pins need to be reflowed and when I say this I mean heated until the entire solder connection melts and flows around the pin, simply touching the glob is not going to cut it and with all that has been done so far I wouldn't be surprised to find blown semiconductors. You're going to need a lot more luck to get this one working right again.
Last edited by ARC Tech-109; 05-13-2024 at 11:06 AM. Reason: Autopost keeps timing out
Old 05-13-2024, 01:16 PM
JohnCT's Avatar
Man, triplers were great - they'd generally arc and burn through and people were so happy when the price to repair the TV was half of what they were afraid of what it would be because of the acrid smoke they'd belch..
As an ASC we had to have a test jig, so I didn't do much lugging. I also cheated a bit - if we had a big tube Sony that was dead, I'd just grab the chassis even though I didn't have any test jig adapters for them and just use a scrapped yoke and HV probe. I kept a bunch of yokes on the shelf for that reason. When I got the power and HV repaired as indicated by the HV probe, I'd just return the chassis.
Old 05-13-2024, 05:23 PM
luRaichu's Avatar
NIGHT STALKER
No, it is not. See the 2nd pic.
Also, I guess it wouldn't hurt to work on the flyback's pads a bit more, and the other things you'd mentioned too...
Old 05-13-2024, 08:04 PM
We didn't cheat so much, I was a 20-something who was bigger than his britches and would literally pick those big tube sets up solo and gracefully load them in the van, now at 55 I'm feeling every one of those on every bump I hit on the road... not so graceful today.
Old 06-10-2024, 07:24 PM
luRaichu's Avatar
NIGHT STALKER
Set was disposed of against my will. Sorry guys.
Was it rare?
