Old 05-08-2016, 10:44 AM
Originally Posted by David Roper View Post
It's got a simple charm to it! It probably sounds pretty good for what it is--and I'm sure gets plenty loud, if perhaps in more of a shrill way than a rattling way.
I worked on a GE that looked similar, but it was SS and a GE Tonal I changer.
It had the tiny black transistors with thin metal heat sinks on them. The low AC voltage for the amp was taken from a tap on the motor winding. The owner's son, tried connecting extra speakers to improve the sound and blew the O/P transistors.
Old 05-08-2016, 01:23 PM
Most solid state GE's from that period used speakers with an oddball impedance (in the 24 to 32 ohm range). He likely connected 3.2 to 8 ohm speakers and I don't suspect it would last long like that. I've had stereos come in where people would connect fix speakers in parallel on a single speaker output on the amp, basically placing a short circuit across the output of the amp and killing the output stage.
Old 05-09-2016, 10:01 AM
I had a VM SS small stereo built in about 1969. This one one speaker per side. 45 ohms impedance. Seemed strange, as most were as you stated.
