I have the Toshiba M649,M769 both from the mid 1990's which I bought brand new .I had to replace the idler gear assembly on each VCR around the same time years ago since the plastic pieces worn out so quick.Both VCRs still work today but they are on backup standby now.I have a third one M648 somewhere here from the same era which is broken and I cant remember what is wrong with it.
Audiokarma |
I worked on four of that model in the late 90's but they all had power supply problems. Sorry...
These VCRs were secretly assembled by Samsung for Toshiba during the early-90s. It bagan in 1988 for some mono models, despite they may look all Toshiba-designed inside.
Yes It looks the same as my two here.Check the idler assembly and see if its ok and not chewed up.I had two go on me in each VCR.Also replace the belt in it too.
Yes I dont really like it but Ive done that too. |
I've looked at the idler gear assembly and it looks to be intact yet, I think it might be mainly a belt issue, but not sure until I can find out what the size of the belts are that this VCR needs because I looked over at SMC Electronics supply and their supply of belts go by the belt diameter and not necessarily by make and model of VCR.
http://www.smcelectronics.com/vcrrep.htm |
Audiokarma |
