Spray some electrical contact cleaner in to the gap where the terminals are on the potentiometers on the inside of the unit and and turn the pots end to end a few times.
I recommend De-Ox-Id as your contact cleaner. I use it, and find it to be a good balance of high effectiveness and low price. https://www.google.com/search?q=De-O...utf-8&oe=utf-8
Outside: http://i.imgur.com/JRY31Vz.jpg Under the hood: https://imgur.com/a/ioAOT Once I get the unit cleaned up I hope it sounds as good as these look! |
Be aware that this unit is creeping up on 60 being years old. The paper and electrolytic capacitors may still be good. but they go bad with age, use (worse yet extended disuse), and storage conditions...You should consider replacing the capacitors on the amp and tuner chassis. Also the rubber on the changer (motor mounts and idler wheel) can go bad from age too if the motor spins but the platter won't, won't at the right speed or there is regular rumble overtaking the audio there may be bad rubber. The cartridge and styli, as well as tubes may also wear out. It may be fine now, but vintage electronics just like vintage cars, only survive multiple decades of use through periodic maintenance.
