Old 08-23-2018, 09:51 AM
bluenorm's Avatar
bluenorm bluenorm is offline
hi guys
thank you electronic. m I will follow your second paragraph to the letter, because I checked those resistors and I know the location. and I replaced r212. will to locate L 45 today and follow up from there. I got your point which is to isolate different voltage points. disconnecting L45 will tell me if the will power supply section is ok and that will be a good start. will u keep inform.
