  #31
Old 01-02-2019, 05:18 PM
jr_tech jr_tech is online now
Originally Posted by Crist Rigott View Post
I cut the Masonite close to the lines with my band saw or Dremel jig saw, then on the outside edges I used my disc sander. On the "inside" edges, I just filed them to the line, and everything got a light sanding with 220 grit sandpaper.
The holes were drilled using a1/4 "Brad Point" drill bit.
Thank you... “Brad Point” drill set added to my vocabulary and my shopping cart.
Is the Dremel jig saw a hand-held device or is it configured more like a small band saw (scroll saw)?
