Can a Zenith 9-160-030 sub for a 9-160-05?
Like the title says, I want to know if they can safely interchange.
I have a NICELY working 13" that uses the 030 and a nonworking 19" space phone set that uses the 05. The 05 looks like it has had a hard life....many burned and bridged traces lots of wear, evidence of servicing, etc, and I'd like to confirm it is the problem by substitution with a known good module before I jump in and try to fix it at the component level (assuming there is enough left of the 05 to fix).
I think the 03 was subbed to an 05. you're going backwards.
CRSP CRSP CRSP - that is the Zenith compatibility manual - remember the title, and the search is easier: http://videokarma.org/showpost.php?p...89&postcount=7 Cheers!
Brian USN RET (Avionics / Cal) CET- Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! Last edited by Findm-Keepm; 09-26-2015 at 08:51 AM. |
Thanks, but that manual lists no subs for 9-160-03 (but it does not say to NOT use any specific variant), and 05 crosses to 04.....It is inconclusive. Perhaps I should just hook it in, start my variac at 70V, and hope I get picture and not smoke.
Audiokarma |
Seems to me when I was working on those Zeniths back in the days, I used to sub those. However I would look at both of those boards and see what differences and changes were made between them. I don't believe you will smoke anything out by subbing them. I'd go ahead a give it a try. Can't hurt. If it doesn't work, at least then you will know.
At one Zenith Seminar in early 84 (I attended with my dad's former boss, A Zenith dealer), they showed a set that was serviced using the wrong module, not sure of the combo, but swapping the wrong module had damaged another module. They also showed off a mod to the ultrasonic remote tester that allowed a tech to check for horizontal drive, a test that allowed you to isolate the fault to the correct module. The ultrasonic remote tester we had already had the IR mod, but I brought back the mod sheet and modded ours - just a resistor and coupling cap - the whole tester was built around an op amp driving an LED to show the pulsing of the remote signal, or with the Horizontal drive mod, the pulsing of the drive signal. Bottom line is, use the CRSP and avoid the problems. It also lists all the duramodules and some digital modules. I have scanned about 80% and posted in various threads - just search CRSP. Cheers,
Brian USN RET (Avionics / Cal) CET- Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! |
I swapped hundreds of 9-160's
IIRC -03 subs to -05 -04 subs to -06 there was also a -08 ( rare) that subbed back to one of them. An 05 or an 06 will sub ANY 9-160 between them. IIRC you can not put the wrong one in due to the yoke plug without forcing it & busting the skt. IIRC also the newer subs used a multivibrater to kick start the set & the old ones a transformer etc. On some, remotes IIRC there is also a cable that gets left off on a sub. Plugged on top & had 2 wires. Just tie it off out of the way. 73 Zeno |
9-160-05R Was the 25Kv HV Module.
9-160-06R Was the 30Kv HV Module. 9-160-08 or 09 were not available as rebuilt as far as I know. Does anyone have an older CRSP book I was thinking until the 08 and 09 came out it was odd suffix subbed odd suffix and even suffix subbed even. The one above: 9-160-05 = 9-160-04 9-160-06 = 9-160-04 Which most likely isn't correct ? Why would Zenith have made both the 05 and 06 as rebuilt replacements ? 9-160-05 would sub an 9-160-03 but not an 06. 9-160-06 would sub an 9-160-04 but not an 05. But the 08 and 09 mixed things up a bit. I think I still have the service seminar for the 9-160 series book somewhere. Then 2 weeks later the told us not to repair any of them exchange only. rrrhre2s Last edited by rrrhre2s; 09-26-2015 at 05:39 PM. |
I've repaired a lot of them and have even replaced arcing flyback transformers on them; but, I always installed a used flyback (usually, in something I was fixing for resell) because the local parts house didn't have them. I was told that Zenith didn't offer the flyback by itself and when it failed, they wanted you to replace the whole board.
http://www.youtube.com/user/radiotvphononut |
Audiokarma |
Never put an FBT in one. The FBT probably was a $30+ part & the whole board a little over $50 Xchange. Swapping the board takes 5 mn,
changing the FBT adds time & wait for part. In the house only changed board or resoldered. If it had a shorted HOT we changed the board. Other things like PC cons, filter cans, the 32 V regulator we would fix only on carry ins. We tried a few HOT's but like a Sony they often ran perfect for weeks then on a turn on BANG. If you gotta make a living you dont want that over your head. Fix it fast & keep the customer happy. Gotta remember this is one of the 3 most complex sets built as far as PS/Hoz sweep goes. RCA SCR & ITR sets ( and clones) & Sonys with 2 SG613's were the others. 73 Zeno Quote:
Okay, I'm going to at next opportunity try to swap the boards. If it works with the 160 from my good set, then I'll try to fix the bad board, and if that fails buy another.
Or do you mean another set ? Beware I have had the 9-152 to damage the 9-160 rare but possible. Found the training manual for the 9-160 service seminar, quaint reading today. I had forgotten just how complicated that board was in it's day. Anybody forgotten the Motorola (Quasar) JA panel ? (was too far ahead of the technology at the time) rrrhre2s |
They never seemed complicated to me. Very easy to figure out. I never bought a rebuilt board. I always fixed them myself those sets paid the bills.
Everyone with "I imagine, IIRC, and I seem to think" - Zenith says otherwise. I have no problems with what others do with their sets - just passing on the facts from Zenith. If someone has contradictory CRSPs, please post for the benefit of all. Edit: Somewhere I have the PTS Electronics cross reference as well - I'm gonna dig it up and scan that - they may have other info as well...
Audiokarma |
