Old 10-28-2015, 06:48 PM
dewdude's Avatar
dewdude dewdude is offline
i <3 my Denon
RCA Radiola 18
Hi guys,
I just acquired a RCA Radiola 18 that I'd like to get running some-day. There's just a few issues:
the schematics I find do not list capacitor values for the AC model, well...it lists a couple but not all. Does anyone know where I can find a complete schematic.
the other issue is just how was the speaker coupled? was it field coil? was there a dedicated OPT for it?
Audio: SMSL M8 -> Little Bear P5 -> Sansui SE8 -> Yaqin MS-12B -> Denon PMA-770 -> Ohm Model L | Ham: NQ4T - IC-7300
[/SIZE][/COLOR]
Old 10-28-2015, 08:13 PM
Olorin67 Olorin67 is offline
not unusual for a set of that era to use a high impedance speaker, no output transformer, they often just connected the speaker to the plate of the last tube. If you use a modern speaker you will need to add a transformer to match the impedance and complete the plate circuit. The schematic should show you the speaker arrangement.
Old 10-29-2015, 08:01 AM
dewdude's Avatar
i <3 my Denon
Yeah. I found a good schematic. IT basically shows the plate of the AF tube going through a .5uf cap and then to the speaker. So it must have been either a direct high impedance connection or had a small OPT on it.
I'll have to look up what the UX-171 requires for impedance. I may have something.
[/SIZE][/COLOR]
Old 11-14-2015, 01:37 PM
teevee's Avatar
teevee teevee is offline
Typical old hi-z speakers are 2k ohms. You can use the speaker and output transformer from a defunct AA5 radio in place of it. These early sets used wax/paper caps for the power supply filters, and they typically are OK.
