"R.C.A." broadcasting gear 1968
I found that I have uploaded it in the past on dropbox: https://www.dropbox.com/s/jste6bfxsp...8-com.pdf?dl=0
I'm confused. When I click on that link, it goes to my dropbox, not to the pdf file.
But now?
There are a number of vintage publications from RCA and other manufacturers on
www.americanradiohistory.com all downloadable as a pdf.
Audiokarma |
It works for me too.
Perhaps your country is blocked from the site. . You could try accessing it from a VPN that makes your computer appear to be connected to the internet in the USA to all sites you access.
The ad for the TR-70 brags about how even yellows are good, and calls yellow "the noisiest color around."
I wonder why that was? Was it because the FM carrier was deviated toward the high end on yellow and starting to approach the end of the heads' frequency response? |
"RCA was referring to overdeviation experienced in Low Band color. Yellow with its comparitively high luminance was a challenge that was largely solved with High band, INTRODUCED in the VR 2000 by Ampex. It used a 10 MHz peak carrier that eliminated so called "bearding" (no RF). The same FM parameters were adopted for Type C" |
I recall however for 1970's studio cameras using plumbicon tubes, the noisiest color was blue. I think this was because blue is low luma and at the low (expanded) end of the gamma curve. |
Audiokarma |
I believe most up-to-date solid-state pickup cameras dispense with the filter change and use only electrical gain adjustments to get white balance. Blue is still the weakest channel under incandescent lighting, but gets a boost under daylight. This is certainly the case with DSLRs used for video, as well as stills. The color splitting prisms in the Plumbicon cameras were designed in conjunction with the Plumbicon tube spectral responses and the assumption of incandescent light to give the lowest possible noise along with good color rendition, but it still resulted in the blue channel being much weaker than red or green. |
I notice they also show the live production of Kraft food commercials in Canada. The live Kraft commercials in the U.S. always had the best color of anything on TV.
It works for me.
While working at an ABC affiliate, we got a program from SCETV that played on Saturday morning called Job Man Caravan. It appeared to be low band when I set it up.
About 10 minutes into the show, it switched to hi-band (done while recorded). You can imagine the surprise when the video went to $#!T. I had never seen a tape do that before. It took me a minute to figure out what had happened. Switching to HB solved the problem.
Did the editors for RCA's magazine's get a bonus for every time they mentioned color TV?
Audiokarma |
