Magic eye tube rebuilding
I have been wondering for a long time where to put the description about the rebuilding of the magic eye tube. After reflection, I decided that I would put in this section, at most the moderator will move elsewhere.
From the original magic eye, I only use the screen, clean it, and apply a new phosphor. The bulb, electrodes, cathode, zero grid and getter are new. For now, I gave up installing the control triode inside the lamp. This function is performed by a small mosfet mounted in a socket. |
That's pretty cool. If I were in your shoes I'd be tempted to phosphor it 3 different colors (green, yellow and red) along the indication scale in order of increasing input on the tube...
Cool ! Now all ya gotta do is make reproductions of the Zenith 6T5, and then watch the bushels of money come rolling in.....
Even the 6U5/6E5 can be $40+ tubes in some places as NOS dries up.
I would have to have at least one bad 6T5 to see exactly its design.
Audiokarma |
I figured this would be a next step from CRT rebuilding. If it's possible to recoat the cathode and re-phosphor the target it should be doable. I believe the 6-pin types use a P1 phosphor, and the later 9-pin tubes probably the P31 phosphor, at least that's what I see based on the colors.
Erich Loepke |
It's too bad an LED variation of a 6T5 or 6U5 can't be fabricated.
Rick (Sparks) Ethridge |
Hi to all,
Hi Titan 1a, Have a look at this color LCD magic eye substitute. Choice of colors, displays frequency & B+ voltage, if desired. No affiliation. https://www.radioelec.com/en/magic-e...4_384-834.html See it working here: https://drive.google.com/file/d/1-3-...m5I9mOdZk/view Best Regards jhalphen Paris/France Last edited by jhalphen; 10-14-2022 at 03:07 AM. |
Wow that's impressive. I never thought to rebuid one.
this is crazy. you may want to post over at Audiokarma, I bet people there would be interested. I myself have a stereo receiver (1961 Pilot 654) with a "Magic Eye" tube for a tuning meter.
Audiokarma |
Thank you . Here I talk a little about my magic eye tubes. Since this is in Polish and you may not want to listen, scroll to the next link.
https://www.youtube.com/watch?v=7epxTy-p32k&t=1065s Maybe this three-color lamp will be a bit crazier https://www.youtube.com/watch?v=7epxTy-p32k&t=1243s |
Interesting
This whole thread is very interesting.
If someone has a direct substitute of any kind for a 6u5 tube would be great. Any info on this in an English web site link or video would be helpful. |
