Old 03-08-2006, 02:26 PM
larschr's Avatar
larschr larschr is offline
TeeVee collector
Can someone identify this tube?
The markings are washed off this tube, and i wonder what kind it is.
I know the following:
It comes from a black and white TV, mid 60s i guess.
It has 9 pins (one not connected) and a top connection.
It is bigger than most other european tubes.
Maybe it is a high voltage rectifyer?
Old 03-08-2006, 02:33 PM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
Horizontal output tube?
all the best,
mrh
Old 03-08-2006, 11:12 PM
John Folsom's Avatar
More likely a damper tube (6v3 for example)
http://www.nj7p.org/Tube1.php?tube=6v3
John Folsom
Old 03-08-2006, 11:32 PM
dr.ido's Avatar
dr.ido dr.ido is offline
Damper diode, possible a PY500 if it was from a european series string set.
Old 03-09-2006, 02:11 AM
larschr's Avatar
TeeVee collector
Yes, it comes from a European set (maybe a Philips). The heater current is 300mA.
Old 03-09-2006, 06:10 AM
Giulio Maiocco's Avatar
Giulio Maiocco Giulio Maiocco is offline
Geloso prototype owner
Hi,
I would bet the tube is a PL500 or PL504.
Just my 2cents
Cheers
Giulio Maiocco
Old 03-09-2006, 01:25 PM
Old 03-09-2006, 07:20 PM
pallophotophone pallophotophone is offline
Put the tube in your refridgerator for an hour or two, then remove it and breathe on the glass. The number may become visible in the glass while the condensation remains.
I've had some luck rubbing with a soft leaded pencil, but the fridge trick most always works.
Bob
Old 03-09-2006, 10:44 PM
peverett peverett is offline
There were several damper tubes with similar to this in appearence that were used in B&W TVs in the 1960s. I have quite a few of these. The 6V3 has already been mentioned. Others are 20AQ3, 30AQ3, 17BR3, etc. I do not know the origin of the tubes, but they were used in sets sold in the US.
