Old 07-13-2013, 02:28 PM
TinCanAlley's Avatar
Are these just holddowns
I took all the press-in modules out for a cleaning and cleaned the contacts. On each module were two blue plastic tubes on unused pins. I looked them over and they serve no electrical function, so I'm assuming they were used to keep pressure on the board to stay seated.
Do I need these? The boards seem to fit snuggly on the pins and I don't see them on my other CC2 (no problems with the boards coming loose).
You can see them in the attached picture on the vertical and horizontal boards.
Thanks
Old 07-13-2013, 11:08 PM
rca2000's Avatar
rca2000 rca2000 is offline
As far as I know...those are just hold down sleeves. Most likely from shipping.
Old 07-14-2013, 10:53 AM
kx250rider's Avatar
REAL TVs have TUBES!
I always try to put them back for aesthetics, but I bet they were intended to insulate higher B+ voltages in case of wandering fingers during setup adjustments, etc.
Charles
Old 07-14-2013, 12:03 PM
Just hold downs, do as you with with them.
Old 07-14-2013, 01:04 PM
They are gone. There is no voltage on any of the pins they covered. Since I don't plan on operating the TV upside down or shaking it, I can do with out them.
Thanks!
