Old 07-12-2014, 09:23 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Capacitor/resistor recommendations?
There are so many types that I could easily end up buying crap. I've been perusing the Digi-Key site as I don't think Mouser has any through-hole resistors, that or I did something wrong. I need to know not just what brands to use but what composition/tolerance/etc.
Thanks
Old 07-12-2014, 10:59 PM
Mouser has over 66,000 through hole resistors http://www.mouser.com/Passive-Compon...ors/_/N-7h7z5/
I like Vishay 2W metal film resistors. They are about the same size as the old 1/2 watters and are a nice deep red color rather than bright blue.
http://www.mouser.com/catalog/catalogusd/646/817.pdf
Here's a photo of some 3, 2 and 1 watt in the center
Old 07-13-2014, 10:49 AM
Jon A.'s Avatar
What are the blue ones made of? I know that I shouldn't exceed the rated resistor wattage on SS sets because resistors can act as a fuse and further damage could be done if a higher wattage is used and something else is amiss.
Old 07-13-2014, 01:10 PM
Oh, I assumed you were restoring tube sets. Smaller ones are metal film. Bigger ones metal oxide.
Old 07-13-2014, 02:22 PM
Jon A.'s Avatar
Right now I'm gathering stuff to fix a CTC88 with a well-known vertical problem. Very limited options with transistors so no problem there. Set seems near mint otherwise and very clean inside. Selecting component brands is my biggest hurdle, so thanks. Still need advice on caps though; I'm sure I heard someone else say Panasonic or Nichicon but I would need to confirm that.
Old 07-13-2014, 02:43 PM
powerking powerking is offline
I would avoid any/all no-name cheap as dirt Chinese branded caps that have been flooding the market. Stick with U.S. or Japanese brands like:
CDE (Cornell Dubilier)
IEC (Illinois Capacitor)
Sprague
Vishay
Panasonic
Nippon Chemicon
Nichicon
Xicon
Kemet
Rubycon
When replacing electrolytics, go for low ESR and high temp rating (like 125 deg C) for the best possible life expectancy.
Tom (PK).
Last edited by powerking; 07-13-2014 at 02:57 PM. Reason: As Bob A aaid: "Agreed and I'll add Rubycon to that capacitor list. "
Old 07-13-2014, 02:54 PM
Old 07-13-2014, 03:07 PM
NoPegs's Avatar
NoPegs NoPegs is offline
The glass is -3dB.
I always forget about Rubycon for some reason. They really do make a quality capacitor for a fair price.
Old 07-13-2014, 03:21 PM
Jon A.'s Avatar
Oh yeah, that's exactly what I'm trying to do.
