Old 12-21-2007, 05:24 AM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Nice ion burn
see
http://bs.cyty.com/menschen/e-etzold...Ionenfleck.jpg
Who has some more photos of ion burns on the screen?
- Eckhard
Old 12-21-2007, 10:19 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
Yikes!
That is scary. The phosphor looks almost completely gone!
Jordan
Old 12-21-2007, 11:28 AM
yagosaga's Avatar
VK Member
Originally Posted by jpdylon View Post
Yikes!
It is not as bad as you think. This photo was enriched with contrast to make it more visible. I have created a Wikipedia article with an actual ion burn photo (with normal contrast):
http://de.wikipedia.org/wiki/Ionenfleck
But with moving images you don't see the ion burn after a while. See this photo from the same tv set:
http://bs.cyty.com/menschen/e-etzold...e/img/LV30.jpg
Who can make more photos from ion burns on the screen? I want to compare these to see whether they look similar or not.
- Eckhard
Old 12-21-2007, 11:50 AM
I have a worn-out Zenith 10BP4 with obvious spotchiness of the phosphor. It isn't concentrated in the center like the one pictured, though. If not ion burn I'm not sure just what it is. It's stuffed way back in the attic but sometime I'll pull it out and get a picture.
Old 12-21-2007, 01:46 PM
mattdavala's Avatar
mattdavala mattdavala is offline
I've seen a couple CRT's with phosphor that flaked off , not related to Ion burns. I am not sure if that is the spotchiness you are refering to. I have a Dumont 15AP4 that is missing a speck.
Matt Davala
Old 12-21-2007, 08:23 PM
nasadowsk's Avatar
Damn does run fast…
I had a Zenith with a spot burnt right through in the center, where the turn-off dot generally is.
I had a rotted tube in a tek scope once that I pinned the brightness on and XY drew by burning off the phosphor. I wasn't the first one to try that 'experiment' on it, either. Tek sold a kit to internally limit the brightness, for just such a reason...
I wonder where the stuff goes, after that, though?
