Old 06-06-2020, 12:13 AM
Jon1967us Jon1967us is offline
GE 14" Safety Question
So, I nabbed a pretty sweet little GE 14T007.
Although I currently am enjoying just admiring it on display, I do plan on embarking on a fair amount of testing. I'm fairly new to this hobby and haven't worked on anything like a GE, which has most of its components hidden on the other side of a chassis "firewall".
I want to put a CRT tester on it and then later test for at normal power for raster with test patterns and will want to discharge the CRT before removing the chassis. I don't see anyway to do that before doing so since I can't get to the anode from the back.
Is there a safety concern in handling the chassis before the picture tube can be discharged?
Old 06-06-2020, 10:45 AM
Notimetolooz's Avatar
Have you restored a vintage radio or two first? That is always a good start.
I wouldn't bother trying to power up the set before you at least replaced the electrolytic capacitors, you could damage expensive parts. Testing the CRT as well as the other tubes first is also a good idea. Clean up the interior is best done before you start the re-cap. When you pull the CRT socket off the tube be extra careful, if there is a bakelite tube base on the CRT it can come loose. It is a good idea to pry the base and the socket apart with a small screwdriver the first time at least, age can make the two stick together. Speaking of safety, be very careful with the neck of the CRT, the glass is the thinnest there, about as thick as a wine glass. The difference of air pressure due to the vacuum is almost 15 lbs per square inch. That means an area 8 inch square has a total pressure of about half a ton on it.
This article by Phil Nelson (a member here) about a RCA set that has a similar cabinet and chassis construction.
https://www.antiqueradio.org/RCA_14-...Television.htm
Old 06-06-2020, 11:28 AM
Yeah I’ve done some restoration and have some experience. Just haven’t worked on a set where the crt anode cap is inaccessible unless u remove the chassis. Just wondering if there’s a way to discharge everything before handling the chassis. Of course the chassis won’t be hot because of it not being plugged in but there may be a possiblilty of charge caps or crt.
Old 06-06-2020, 11:54 AM
Not familiar with this chassis, but it looks like the panel with the high voltage dischage label swings open to reveal the flyback and rectifier, so you can discharge at the rectifier output.
Old 06-06-2020, 05:52 PM
Now THERES an idea!
Old 06-07-2020, 08:28 AM
Except the CRT anode is connected to the rectifier BASE, not the cap.
Old 06-07-2020, 09:38 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
Discharging at the HV cage, whodathunk!.
On my kcs96 (chassis wrapped around the picture tube neck) it didn't matter how many times I discharged the HV lead with the long screwdriver it still managed to zap me when I reached my arm in there to unhook it from the pic tube. On that set if I take the yoke off I can get my arm in there between the chassis and pic tube neck.
Old 06-07-2020, 10:28 PM
I have done 3 of these sets. You have the early version. Chassis removal is a pain....I think I got the chassis half way out such that I could reach the HV connector on the CRT and discharged it with a probe. I have the Beitmans service manual (a reprint of GE service manual) for the late set and it reccomends crushing defective original caps and resistors on the PCBs and twisting the old and new component leads together and soldering....I have to agree with that approach....the solder side of the PCB is blocked by the chassis and unscrewing the boards to get at the solder side usually destroys the factory board standoff grounds and involves unsoldering several wires...
HV dielectric bounce back!...It is a treacherous bitch. On almost all sets you will get it if you dead short the HV to discharge. The best way to avoid bounce back is to discharge the HV through a resistor 1M or higher....I almost always use my HV probe to discharge and never get zapped when I do....it's always when I cheat and dead short the HV (or neglect to discharge it at all) that I get shocked....
Old 06-07-2020, 10:37 PM
getting shocked ( i mean by the HV) is half the fun with old sets like these!
you have not lived until POW-ZAP! your hair is standing on end!
Old 06-08-2020, 11:22 AM
Ooh I've lived plenty...Ever seen the movie office space?...I kinda regard the HV stored in a powered off set like the protagonist regards that staticy doorknob: a necessary annoyance. I hardly even flinch in most screwups...just cus a bit.
The real scary thing to get bit off of is the yoke and the H output top cap of a powered on set...those can supply lethal current, and even if you don't get it across the chest and live to tell they will still char your skin and leave a nasty burn...I have learned that the hard way twice.
When dealing with a powered up set everyone should always keep one hand in a pocket or wear rubber gloves...
Old 06-08-2020, 10:54 PM
I have no problem with the crushing/J-hook method. I just did some of that on my Philco. I didn't even have to take the chassis out - just worked on the IF board with the back open.
The term "dielectric bounce back" is a new one to me. I didn't know what this was called, however I was observing this phenomenon the other day with a pair of electrolytics, a voltmeter, and test clips with and without a bleed resistor, and sure enough it's the case.
Old 06-06-2020, 08:19 PM
Tom9589 Tom9589 is offline
What makes this set even more rare is the UHF tuner. You rarely saw them until they were made mandatory in the 1960s (unless you had a dominant UHF station in your market). This set is definitely worth restoring if no major component is dead.
Old 06-06-2020, 09:04 PM
Yeah and the dial string is broke. You can see the broken end sticking up.
Old 06-06-2020, 10:53 PM
I don't remember if you can remove the chassis from the back on this one, or if you have to remove the CRT and go out the front, either way you should be able to have enough slack to reach in and remove the anode connector from the tube, just slip a grounded screwdriver under the cap to discharge it.
You have to slide the yoke off the CRT as you go so loosen the clamp and remove it first,
Old 06-07-2020, 10:43 AM
I'm no stranger to working on that set! It's kind of tricky to remove the chassis. You have to reach in from the right side to remove the second anode lead, after removing the yoke. You might have to remove the speaker too?
The last one I took apart, I scrapped.
The one shown is the real cheapie model, no handle!
IDK if that's the early or late production? The early one uses a 5AN8 in the horiz AFC and audio IF, where the later one uses a 3AU6 and diodes for the AFC.
I had a Motorola that was similar, but was a lot better.
