Old 03-21-2011, 07:39 PM
chipper chipper is offline
Ballast tube replacement for pilot tv
Has anyone replaced the ballast tube used in the model tv-37 set, with 15w resistors, if so can you show or tell what you did to replace this hard to find ballast tube. thanks
Old 03-21-2011, 09:39 PM
Findm-Keepm's Avatar
Followin' the Rules...
Are you talking a Pilot TV-37? If so, I don't see a ballast tube in the schematic:
http://www.earlytelevision.org/image...-rider-tv2.pdf
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 03-21-2011, 10:03 PM
M-4
OK: On photofact(pilot model tv-37) /set 62 folder 16 It is listed as M-4 ballast tube.
Old 03-21-2011, 10:18 PM
When I first got my VT-71 I did some dumb things; I managed to cause a meltdown in the ballast, destroying one of the elements. I think I ended up putting one or two resistors inside the old cage and maybe mounting a third under the chassis, but that has been a few years ago. It did work just fine. I guess I need to look at my Pilot as I don't recall what it uses exactly. I do know that both of the Pilot radios I own (and they are both huge table models) use a ballast which seems out of place.
