#61
Anyone know if there are any differences between the 20X1 and 20Z1 chassis, other than the control locations?
#62
I've pretty much finished buffing out the cabinet. The grooves were actually pretty easy to clean out. ![]() Here's a closeup of an area that was sanded and one that was just polished. I wonder if something like black shoe polish would help any ![]()
#63
It looks very nice as is.
Personally I sort of like a duller satin look on Bakelite, especially after dust settles on it, because there's always dust around here.
#64
Yeah, I know what you mean
That's another reason I don't like using oils or waxes on bakelite - the dust sticks to it.
#65
I cleaned up the brass outer knobs with Brasso followed by Simichrome.
I let the inner knobs soak in some diluted 409 then buffed with Novus #2. ![]() The power cord is all brittle and cracking. Luckily, I have some NOS replacements. I carefully removed the old cord while preserving the rivets. I read that it was possible to soften the replacements in hot water and mush them over the old brass rivets. It actually worked ![]() ![]() next, I replaced the old crumbly faceplate foam with some closed cell insulation held on by contact cement. ![]() ![]() And so another project comes to an end
#66
I must say that's some mighty fine TV restoration work there.
![]() Does that semi chrome keep the brass from tarnishing for a reasonable time, or do you end up clear coating with lacquer? |
#67
Thanks. The Simichrome can claims it will prevent tarnish from returning. I suppose the longest I've had bare brass treated with Simichrome is 2 years and it looks OK. I have coated some knobs with Mohawk lacquer formulated for brass and they look like new after a couple years too. Time will tell.
#68
Bob, as usual, that set looks and functions super. Good Job! and thanks for the tip on how to replace the cheater cord. I don't have those rivets either so I had to resort to something not as pretty. You can bet I will try your trick for sure!
#69
Just curious - where did you find those cheater cords? It's not like you can go to Wal Mart and buy em.
#70
![]() Quote:
Maybe try setting up a search on eBay for "cheater cords" with email alerts. I'm sure some will pop up eventually. |
#71
Another excellent restoration project Bob, I've been following this one on You Tube as well... You must be seeing Admiral TV's behind your eyelids by now when you close them!
![]() Out of curiosity how big are these sets dimension wise? I'm guessing they're quite compact going by the pictures... Great stuff anyway, I always enjoy your posts/videos. ![]() Cheers Glen
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/ My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn |
#72
Thanks. Yeah, I've pretty much memorized the schematic by now. It's nice to have a couple of the same chassis for comparison.
It is pretty small as vintage TVs go - about 18" deep, 15" tall and 14" wide. |
#73
Excellent work! Your set seems to have just left the factory
#74
Hey Bob - I've been working on my Admiral tuner and I noticed in your vid "Admiral 20x11 restoration part 4 of 5", it doesn't appear that you put parts M!05 and M113 back on (the clip and the washer) at12:09 in the vid. I do see you remove them (at least the washer) in 10:48. Am I missing something? I was trying to figure out how mine went back in.
#75
I think I forgot to put them back on when I recorded the video, but I did later. I could take some photos if that would help.
