Old 06-08-2012, 11:40 AM
What happened to your TV was a shame. I also like these sets; never owned one, but I knew a kid who lived on the next street over from me in my hometown whose family had a 3-way RCA console similar to yours. In fact, when I saw the front control panel on yours, it reminded me of my friend's folks' set which was also, IIRC, a roundie.
It would be great if you could get your set working again as it once did; in fact, I hope you do, as they don't make televisions (or anything else, for that matter) like that anymore. I'd try to find a junker CTC16X chassis and just do a one-to-one swap -- take out the sabotaged chassis and install the "new" one.
I don't know why anybody would want to destroy a TV like yours (or any other set made by former American quality TV manufacturers such as RCA, Zenith, Magnavox...). If the person who sabotaged your set took the yoke, it may well have been because of the copper in the windings; same for the power transformer and anything else with wire or coils.
Old 06-08-2012, 11:44 AM
Pretty sure the yoke from a '15 will work on a '16. Need somebody else to confirm.
Old 06-08-2012, 12:24 PM
rick65's Avatar
rick65 rick65 is offline
Looking back through my RCA catalogues, listed in 1966.
The WAYLAND Mark XI Series HG-759 - RCA Victor's lowest-priced Color TV Home Entertainment Center. Contemporary lowboy cabinet high lighted by richly patterned fabric grills and detailed vertical wood paneling. Selected hardwoods veneers and solids in Autumn Mahogany grain or Natural walnut grain. Same components as HG-765 except sound system includes two 3 1/2" tweeters instead of four. H-31 1/4" W-57 5/8" D-26 7/8"
Available without FM Stereo: Mark XI Series HG-755
I also had noted a retail price of $700.00
Old 06-08-2012, 12:48 PM
marty59's Avatar
marty59 marty59 is offline
Here's the chassis.....not a loose wire to be found.
Old 06-08-2012, 01:11 PM
miniman82's Avatar
First Light: 1952-2011
They didn't get the copper out of the flyback! lol
Evolution...
Old 06-08-2012, 01:20 PM
All the RCA roundie yokes were the same from CTC7 to CTC20. Even the CTC15 clones were all the same.
Old 06-08-2012, 01:46 PM
DavGoodlin's Avatar
Motorola Minion
That fly is probably good too. There is more copper in a set of good jumper cables. What a buncha pea-brains
Old 06-08-2012, 02:07 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
WOW.. look at how clean looking that chassis is!!!!
Charlie Trahan
Old 06-08-2012, 02:15 PM
Charlie's Avatar
On Land
Even the flyback looks awesome!! Come on, Marty.... just how bad is the cabinet sides? Can't we work this out? It really is cool looking. i would think we should be able to piece together everything you need to bring it back.
Charlie Trahan
Old 06-08-2012, 04:31 PM
Just a reminder to reflow the two ground stakes on the far right end of the chroma board. They exist in one of two states: either already cracked or gonna crack and cause the heaters in the 6GU7s to go out.
Old 06-08-2012, 11:17 PM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Restore...restore!!!
Old 06-09-2012, 03:12 PM
marty59's Avatar
Originally Posted by Phil Nelson View Post
Yes, I followed a tip from John Folsom and used silver-filled epoxy to reinforce a weak solder joint to a pin lead at the glass surface of the CRT. The TV was a Capehart-Farnsworth 661-P. Here's the thread:
http://www.videokarma.org/showthread.php?t=251233
Phil Nelson
Phil's Old Radios
Phil, thanks for posting that link. The additional comments provide some good information for such repairs. I may try either soldering directly as my original thought or the use of solder wick as a pad and attach my lead to that. Being a filament lead, I need to make sure that connection will handle current flow.
Old 06-09-2012, 06:05 PM
wkand's Avatar
wkand wkand is offline
Ctc15
Any possibility that the one-off power tranny, yoke, etc, could be used to restore the vandalized chassis? I realize it would be a mountain of work.
Old 06-13-2012, 09:52 AM
marty59's Avatar
I tried unsuccessfully to solder to that filament pin....I believe I have two problems here. The break is below the glass surface so all I have accessable is the tip of the wire. I do have a bit of a cavity to work with.
The second issue is that the glass surrounding that wire tip is acting like a heat sink, preventing me from making a good connection.
I afraid to grind down to expose more wire at the risk of further damage but I don't believe I have much choice
Old 06-13-2012, 11:04 PM
Since you are able to get a wire in there secure enough to light the filament, maybe just pressing the wire tight and filling with the silver epoxy will be sufficient.
