Old 07-02-2013, 11:16 PM
azbigsam azbigsam is offline
Transporting a Predicta Pedestal
I have the oppurtunity to buy one of these. It is about an hour away from where my brother lives so he would be picking it up for me. He has a 2005 Mercury Montego. It is a midsize car. Do you think he will have any problem getting it into the back seat? Can someone that has one give me the overall measurements?
Thanks.
Old 07-02-2013, 11:19 PM
CRT is about 2 feet wide and the whole set a little over 3 feet tall. It should fit lying face down across both seats.
Old 07-02-2013, 11:47 PM
I carried mine home in a 1994 Mercury Sable, if I remember right.
Old 07-03-2013, 03:20 AM
WISCOJIM WISCOJIM is offline
46 tall, 17 deep, 23 wide. If you measure the car, make sure you have enough room between the door armrests. I transport these face down in a bed of pillows and old comforters. Make sure there is plenty of packing to keep the TV on the seat and prevent it from flying forward, damaging the TV and the upholstery. The boomerang shaped front foot can make it difficult to position the set securely on it's own.
Old 07-03-2013, 07:46 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Ooooh.....I hope you get it. Looking forward to pix.
Old 07-03-2013, 12:24 PM
Thanks everyone for the info and advice. Here is a pic from the seller.
File Type: jpg 3Ga3Ld3Ib5Ld5G15Ebd6je74c1bad65681b44.jpg (13.0 KB, 29 views)
Old 07-03-2013, 01:52 PM
The head can be removed fairly easily, everything unplugs.
The hardest part is unplugging the HV lead from inside the Flyback cage, you have to be real careful not to damage the Flyback by bumping into it, they are brittle at this age.
Loosen the lock bolt at the back of the collar and the head lifts right off and the wiring feeds through the hole, a two person job really to guide the wires through.
