Old 08-24-2013, 10:46 AM
omegaman omegaman is offline
Zenith chassis 5808
I got this in from a friend who picked it up gratis during a home inspection, a common thing he says since he is there, with a truck, with the owner, doing an inspection, near the "must-get-rid-of-it" terminus, looking into everything and coming across these items
The radio seem to be intact but I have not pulled the chassis yet. I'll do a complete recap on it.
This Zenith has had its field coil speaker removed and the baffle replaced by, what I can only guess, to be speakers someone had on-hand or could get nearby (ie; RadioShack)
The speaker wire is just cut clean, no connector
The questions are:
Did they modify the radio circuit to replace the inductor with a big resistor to use this crossover setup?
or
Did they just showcase the radio and use it as a ha ha cool speaker?
The Yamaha woofer is an "instrument speaker", Do guitar speakers use crossovers and tweeters? or does this say Hi Fi application?
I am looking at a Zenith field coil speaker on the bay as a replacement speaker and wonder. It has the 5 pin plug like my 5 pin socket
IS A ZENITH SPEAKER CONNECTOR AND FIELD COIL AND SPEAKER KIND OF INTERCHANGABLE?
I don't have this speaker but was wondering if it might be a replacement
Old 08-24-2013, 02:04 PM
marty59's Avatar
marty59 marty59 is offline
There would have been an output transformer mounted somewhere as it's part of the speaker assembly too. Only four of the pins are used.
I'd pull the chassis and see what has been done before going any further and a three amp fuse is really too high of a value for this set and should be mounted someplace safer.
Old 08-24-2013, 02:14 PM
Is that the transformer mounted on that speaker in the picture
I'll pull the chassis and take pictures
I'll correct that 1940 fuse installation and go 2 amp
Old 08-24-2013, 08:03 PM
Did the speaker in picture #3 come with the radio? If so, it looks like a P.M. type replacement speaker was used. It looks like the choke was mounted, where the output transformer should be mounted. The output transformer looks like it's behind the metal bracket mounted on the magnet housing. The original speaker should a 10" with a 1250 ohm field and a output transformer for a single 6F6 output.
Mount the fuse holder under the chassis. A 1.5 to 2 amp SB fuse should OK.
If the fuse should blow, you'll have to remove the chassis to investigate the cause anyway.
Old 08-24-2013, 08:23 PM
Did the speaker in picture #3 come with the radio? No. I was thinking of buying that speaker as a replacement. Seems not to be a match though
The original speaker should a 10" with a 1250 ohm field and a output transformer for a single 6F6 output. . That is good to know.
Mount the fuse holder under the chassis. A 1.5 to 2 amp SB fuse should OK. I promise, I'll get that squared away
Is it possible to get it working with this new speaker set up?
Old 08-24-2013, 09:01 PM
That speaker is a lot more promising than the setup you now have.
BTW, the speaker baffle looks like the original factory issue. It was removed and altered for the speakers installed. Also, the radio appears to be a model 8S463, ca1940.
Old 08-24-2013, 09:14 PM
Thanks for the model 8 S 463.
I got the schematic from Radio Museum and a look at what the original speaker looks like
I'm thinking the new speakers were never intended to go with the radio, that the unit was used as a speaker box
The eBay speaker I was interested in is for a Zenith 8S463 which does NOT have a 6F6, which asserts that the speaker would not be correct
Whats the best thing to do to get the system up and running? Find a correct replacement?
Old 08-25-2013, 10:45 AM
If the speaker shown is reasonable enough, it's a good start.
It looks to have a choke and an output transformer, plus a 5 pin plug.
The cabinet looks to be great condition, which for me is a plus.
Old 08-26-2013, 09:56 AM
marty59's Avatar
8-S-463's are "fairly" common and with a little time I'd bet a speaker will show up. Here's what you need..
Try these sites for parts..
http://www.oldradioparts.com/
http://www.vintage-electronics.com/
Old 08-26-2013, 06:56 PM
Thanks for the info Marty
I have been here before, hunting a part, waiting for one to surface
I hate to put it aside but I am going to have to store it until I find a speaker
I still have to look under the chassis for capacitors and what not
