Old 05-17-2015, 12:06 AM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
I actually have that remote, but I don't have the set. If you want a picture of the battery let me know and I can take a picture of it. Very rare and expensive option. Awesome score on this set!!!
Scott
Old 05-23-2015, 10:46 AM
droptop's Avatar
droptop droptop is offline
Behind in Time
Originally Posted by CTC9A View Post
Great about the battery huh? What did you do about the physical aspect of the battery? Did you just stuff the housing so the cross supports for the screws sprung against something? I did notice the 9V tap was used and was thankful! Also, since nothing in the field manual even mentions this remote, what functions does it actually do? On/off/mute and channel or more?
I wanted to preserve the original batter so I changed the connector to a standard 9 volt snap on & used a piece of foam rubber to keep it from moving around inside.
The left Picture buttons turns the set Off, the right one turns it On, then Mute and Channel.
Old 06-04-2015, 12:41 PM
CTC9A's Avatar
CTC9A CTC9A is offline
That is very similar to what I did too. I had the original battery. I used some heavy card stock to make a sleeve for the new 9V battery. Then I soldered clips to a standard connector to slide onto the original plug. This way I was able to support the bottom brackets easily. Radiotronman, thank you for the offer of the image of the battery though!
Old 06-04-2015, 03:07 PM
You're welcome!
Scott
