Thanks Phil! Yes, I had been reading your excellent notes. BTW, I also have a '41 Philco BOL... (no remote with mine but a nice radio). And I will probably be picking everyone's brain as I go along. I'm strictly amateur and learning as a go (over the past several decades)
Wow, so maybe it is stock. I was thinking it probably wasn't because the gold V on it is flat and looks like a knock-off. And, unlike RCA V's, it was glued to the grill cloth rather than pinned. the base is print on hardboard too but the TV is veneer.
Andy, I actually have 2 (well, my CTC9A - Darcy is from early 1960) from this area. The Darcy lived in River Oaks and it looks like this one was in Montrose but I found it down near NASA. There has always been a lot of money in Houston. It isn't like in the northeast but we have our bits and pieces that turn up.
I need to pull it to double check but I believe it is. I think it only runs on one tap though so probably at the full 13.5 volts. It would be too convenient if it ran on the 9v tap! So far, I haven't found much on the remote. Looks like the "sound" may just be a mute. Not sure about the "picture" buttons since they are locking. it may just be on/off mute and channel select. If so, it has one heck of a big sub chassis for it!
-Steve D.
Please visit my CT-100, CTC-5, vintage color tv site: http://www.wtv-zone.com/Stevetek/ Last edited by Steve D.; 10-02-2018 at 05:36 PM. |
Your remote appears to be the same as used on my Grenoble CTC 7. The original battery and plug were intact and it was connected to the 9 volt tap. I swapped connectors for a standard 9 volt battery and it works fine. The only problem I had was two of the 5 K ohm relays on the remote chassis that were open. I was able to find modern relays and after adjusting contact clearance and using lighter springs it works great.
First Run!
Wow! I patiently brought her up on my variac and took my time. This was what I was rewarded with! It has a long way to go but not bad for a first run after who knows how many years. I think there is a lot of good to work from here! I'm super excited. After a while the vertical linearity started shifting, etc.... some cap work to be done but STILL! WoW!
Wow is right. When I consider replacing components in a mostly-working original set like that, I keep in mind the old doctor's precept: "Above all, do no harm."
Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
That is a good picture - especially on original parts ! !
That is pretty darn good for an unrestored example.
I dig that the remote stores in the front control panel.
Big time. |
