Old 04-21-2019, 08:24 AM
kf4rca kf4rca is offline
LG 42LB5800 LED Woes
Picked up this 42LB5800 from the roadside. Its a 2014 model. It rattled when I moved it. Turns out all the lenses had fallen off. Not a big deal to reglue them. The screen looked good!
But 6 LEDs were burned out. So, in my quest to replace them I turned to Ebay and ordered a strip of 10. They were listed as cold white, which is what I needed, but it turns out they glowed yellow. Do they need to burn in?
So, I ordered a second set of LEDs from another supplier, that also listed them as cold white. I couldn't get them to turn at all (either polarity).
So, does anybody know the trick to obtain the proper LEDs for these things?
There are 4 rows of 8 LEDs each so changing them all is not an impossibility. Thanks.
Old 04-23-2019, 05:33 AM
dr.ido's Avatar
dr.ido dr.ido is offline
I just pull the strips from broken panels - never tried actually ordering them.
Old 04-29-2019, 08:31 AM
There are two types of lenses used in LED sets. The domed ones use a smaller LED than the cylindrical ones. I've never seen the domed ones fall off.
So I've decided to re-assemble the rattlevision. It had been dissassembled on the LR floor for 2 months.
The results are good even with the yellow LEDs. I'm thinking the yellow is caused by a lower than expected voltage. You really don't notice it unless you know where to look.
Old 04-29-2019, 01:07 PM
LED color doesn't change with dimming, so those are simply yellower LEDs and always will be.
Old 04-29-2019, 01:32 PM
You know, you are absolutely right. I should have known that.
I'll put up with it like that till I can locate the correct LEDs.
Most likely I'll find another rattlevision on the roadside since this problem seems to be endemic to this series of sets.
Old 05-28-2019, 03:25 PM
rcaman's Avatar
rcaman rcaman is offline
good luck on gluing of those lenses. pita
Old 06-04-2019, 11:17 AM
Not a problem. There are 3 little indents on the lenses that align to protrusions on the strip. I used small drops of Ultrablack from the auto parts store.
The only problem is if you have to replace an LED, then your alignment might be "off" a little.
There is a procedure on Youtube using a piece of diffuser to align them correctly. Works pretty well since I had to replace 6 LEDs.
