Old 05-09-2023, 06:10 PM
Originally Posted by Chris K View Post
Parts list in the schematic and DigiKey? Not exactly clear on what you’re asking. The only “kit” for restoring vintage TVs I’ve seen is an eBay seller who puts together vacuum tube sets for different Predicta models.
I would never trust any "Kits" found on eBay as a source of parts for any vintage project, always best to build them yourself from the SAMS list and dirctly from Mouser or DigiKey, there are WAY too many counterfeit parts out there, and going through a disto like Mouser or DigiKey, you are assured to get REAL genuine parts.
Old 05-09-2023, 06:12 PM
pac.attack76's Avatar
Stuck in the past
Sounds good. I'll go through one of them then.
Genesis does what Nintendon't
Old 05-10-2023, 07:03 PM
Chris K Chris K is offline
Talking about complete sets of replacement NOS vacuum tubes and not caps, resistors, parts etc.
Old 05-12-2023, 08:03 PM
Another great source for caps and resistors is Dave at just radios. He ships out of Ontario Canada so it might take a bit longer to get if you're in the USA but he specializes in parts rated for tube gear and has the parts you need.
https://www.justradios.com/
Before you go to do a recap I'd pull the rectifier tube and check the transformer voltages and test for shorts considering how much outdoor time it's had.
Old 05-12-2023, 08:21 PM
Stuck in the past
Thanks. Does it need to be plugged in? Probably a dumb question, lol
Old 05-12-2023, 11:02 PM
Yes if you are going to assess voltage out of the secondary but you can check continuity of the primary and secondary coils using an ohmmeter and pulling the rectifier tube makes that easier as well
Old 05-13-2023, 08:56 AM
But make sure it's UNplugged when checking continuity.
Old 05-17-2023, 02:07 PM
Stuck in the past
Which one is the rectifier?
Old 05-17-2023, 02:19 PM
init4fun's Avatar
init4fun init4fun is offline
It's the 5U4, the big tube in front of the (very rusty) power transformer.....
Old 05-17-2023, 07:38 PM
Old 05-17-2023, 08:33 PM
got a WEEE bit of rust there, dont we? :P
Old 05-18-2023, 08:35 AM
Stuck in the past
Ty. I'll check this week and post what I find.
Old 05-21-2023, 04:23 PM
Stuck in the past
Pulled the 5U4 only to realize I have no idea what I'm doing lol. I hate to ask but I need to know what setting to put my meter on and exactly where to put the leads. Also need to know what reading I should get. I'm not well educated on tvs especially anything before 1970. After 40 years, I'm still learning.
Old 05-21-2023, 09:26 PM
The 5U4 is a Beefed up 5Y3 tube, and the pins you want to check for continuity (and thus you'll use your continuity setting on your DMM, and or your resistance setting) is pins 2 and 8 of the tube which are your heater pins, if you have no continuity between pins 2 and 8 on the 5U4 tube then the tube is bad.
Old 05-21-2023, 09:43 PM
Stuck in the past
Ah OK, ty. I'll check it tomorrow
