Old 05-06-2023, 08:11 PM
pac.attack76's Avatar
Stuck in the past
1950s General Electric 21"
Anyone know the exact year and model? I couldn't figure anything out with what's there. Also, how do you get the front glass off to clean behind it? Cabinet is steel in black.
Genesis does what Nintendon't
Old 05-06-2023, 10:56 PM
My brother had a GE set identical to that. Bought it brand new around '55 give or take a year. Don't know the model#, but it had an unusual feature: The chassis and CRT were mounted as a unit to a plywood base and the cabinet shell and glass just lifted offa that. I remember watching 'Key Largo' with Edward G. Robinson on it.
Old 05-07-2023, 09:26 AM
Stuck in the past
Service manual says 56 so your right on. Now I remember, some of these were built that way. No wonder I couldn't figure it out and that explains why it look the way it does in there and the reason it has a wood bottom. I'll try to remove the shell today.
Old 05-08-2023, 08:40 AM
Stuck in the past
Remove a nut and washer inside at top right corner on crt and 4 screws on bottom, then the outer body and front slide forward away from screen. Was able to clean everything. Everything seems in order except for replacing the old speaker which is deteriorated. Not sure where to find a replacement yet. Can I safely test this unit or will I need a variac?
Old 05-08-2023, 01:09 PM
mrjukebox160 mrjukebox160 is offline
You could use the "dim bulb" set up to safely test it. https://hackaday.com/2022/11/13/powe...m-bulb-tester/
Old 05-08-2023, 04:39 PM
I've got one that's a year older than yours with a series string chassis.
You could dim bulb it, but most likely there's not going to be much activity. By the look of the transformer and tube shields it's been in a wet shed for along time. Most of the caps in this set are wax paper. If it were me I'd rather even jumper in some new caps before powering up. At least in the horizontal osc / output, boost filter, vertical osc / output and bring the electrlytics up slow on a dim bulb.
Old 05-08-2023, 04:51 PM
The set was possibly in a flood, underwater, by the looks of it. The speaker and everything else.
Old 05-08-2023, 08:42 PM
Stuck in the past
I'll look into replacing some caps before I do anything else. Wasn't in a flood. It was in storage up to the point where it was left outside in an old pickup bed. I found 4 different sets left out like this. Ones actually working. The other 3 need going through.
Old 05-09-2023, 10:15 AM
There's so many sets around for free, or next to free. All you have to do is look for them! You might have to go out of state for good items.
Pull the CRT's and other usable parts and st-can the rest.
Old 05-09-2023, 11:10 AM
DavGoodlin's Avatar
Motorola Minion
That GE is a rare model so, good luck on restoring. It generates interest from anyone *bored* with the most common GE's, me included.
A transformer-powered, dip-soldered chassis with no PC boards. 1956 for sure! Most 21" models from 57-58 year had a U1 and U2 chassis with power tuning and first generation of GE printed circuit boards.
I have a 21" Motorola 1959 built in a similar manner but its series-heater, top and side panels that slip into or screwed onto a frame.
-Dave G
Old 05-09-2023, 12:22 PM
It was a common set where a lot of GE products were sold. I ran into quite a few of them, helping out in a second hand TV store.
One of the technicians I used to work with always said, "I'm can't see why GE is still making TV sets. They don't have that big of a share of the market."
Old 05-09-2023, 01:12 PM
DavGoodlin's Avatar
Motorola Minion
Locally, GE appliance dealers did TV and audio (as a sideline) or alternative to RCA. Unfortunately, most of the uber-cheap sets I saw were 57-later GE, in fact I thought this set was using a 17" CRT-based series heater chassis. The channel knob really threw me off until I looked at all the pictures. It was not unusual to find a cheap-model metal-cabinet TV in a farm dump, most had bullet holes
-Dave G
Old 05-09-2023, 02:31 PM
Stuck in the past
I've got it cleaned up and ready to recap. Really interested in seeing this one run again. Is there a cap kit or restoration kit available or will I have to hunt each piece down individually?
Old 05-09-2023, 05:30 PM
Chris K Chris K is offline
Parts list in the schematic and DigiKey? Not exactly clear on what you’re asking. The only “kit” for restoring vintage TVs I’ve seen is an eBay seller who puts together vacuum tube sets for different Predicta models.
Old 05-09-2023, 05:37 PM
Stuck in the past
Yeah, I just thought it would be nice if they had a collection of caps, etc. For individual sets. I'll have to make note of the ones in there and get replacements. IF I can tell what the values are.
