Old 08-08-2023, 07:57 AM
One thing you can try, remove the plug for the convergence PCB, and do a resistance check from pin 6 on the convergence socket on the chassis to gnd, should be about 1 to 1.5 ohms.
Old 08-08-2023, 09:29 AM
All the other voltages are updated on the last previous page unless the page advanced to this page
Old 08-08-2023, 09:50 AM
plz do the resistance check mentioned above.
Old 08-08-2023, 10:07 AM
Look like 1.8 ohms
Old 08-08-2023, 12:40 PM
Sams says that winding is 1.1 ohms, not sure if thats close enough or not, I don't remember if you have the original FBT in there or not.
You may want to do the same resistance test at pins 13-14 on the FBT, if its noticeably lower than the 1.8 you saw at the socket, it may be a sign of a lose solder connection.
At this point it would have done you good to have an oscilloscope, to see if you had the good signal at 300v at pin 6 on the convergence socket.
That would go a long way to sorting this out.
Old 08-08-2023, 12:54 PM
I probed the wrong wire it’s 1.1 ohms and it’s the original flyback.
I’ve tried to post a pic of what the screen looks like but can’t size the pic right to post it.
I measured the A19 coil wrong there is .9 ohms on both secondary sides and primary is good 2.6 ohms
Old 08-08-2023, 06:17 PM
There is r166 and r167 and c116 at the burst gate maybe those resistors could be stopping the flyback signal.
Old 08-08-2023, 07:13 PM
Here’s the voltages
V21. I probed the wrong side of v22 it does have voltage. I missed B section of v19 I’ll post the voltages
1 180.6
9 -44
6 352.3
3 123.7
7 180.2
2 123.3
Timmy, on V21 do pin 2 & 3 really have the same voltage on both pins....?
Can you investigate this ? Can you check resistance compare to Sams
on these pins? Possible short in the socket, or internal to the tube?
I'm not sure about R166, R167, & C116... Not sure what to do
with the flyback pulse at this point. I would be happier solving
the odd voltage stuff first & being somewhat sure those items
look like they are working.... If you guys want to pursue
the flyback pulse it's ok, I just don't know how your
going to test for it. But we could test for the tube
voltages with the tools Timmy has.....
Either thing could be just a tail
chase anyway....
Old 08-08-2023, 07:21 PM
Here’s the voltages
1 180.6
9 -44
6 352.3
3 123.7
7 180.2
2 123.3
chase anyway....
I’ll check those pin voltages again does seem odd.
Old 08-08-2023, 10:02 PM
I just find it a bit odd that all the negative voltages related to that winding are not where the should be, V19 p9 , V4 p3, V21 p9 , there has to be a common cause, right?
Especially when there was that time when pins 13 -14 on the FBT were reversed.
Old 08-09-2023, 06:38 AM
Here’s the voltages
1 180.6
9 -44
6 352.3
3 123.7
7 180.2
2 123.3
chase anyway....
Ok maybe I probed the wrong pin again, so v21 pin 2 129v pin 3 366v and resistance on those 2 pins 85k and 11k
Old 08-09-2023, 10:12 AM
Would v6 have anything to do with this color issue because I have a resistor on pin 8 2.7meg but it’s up to 3.9meg , Searching for any other bad resistors.
Old 08-09-2023, 11:56 AM
Doubtful.
What I still find odd, are the abnormal voltages you posted, and what may be the cause.
V21 pin 9 @ -44 , should be -130v
V4 pin 3 @ - 1.71v should be -10v
V19 pin 9 @ -40v should be -75v
Old 08-09-2023, 12:05 PM
Doubtful.
The v4 pin 3 -1.71 was flashing
And the 2 resistors and the .01 from the coil on the flyback to the burst gate are good.
Old 08-09-2023, 12:36 PM
That “flashing” is most likely due to the DVM being disrupted by the horizontal pulses on that line, an analog meter would not do that.
