" Here’s the voltages V21. I probed the wrong side of v22 it does have voltage. I missed B section of v19 I’ll post the voltages 1 180.6 9 -44 6 352.3 3 123.7 7 180.2 2 123.3 " Timmy, on V21 do pin 2 & 3 really have the same voltage on both pins....? Can you investigate this ? Can you check resistance compare to Sams on these pins? Possible short in the socket, or internal to the tube? I'm not sure about R166, R167, & C116... Not sure what to do with the flyback pulse at this point. I would be happier solving the odd voltage stuff first & being somewhat sure those items look like they are working.... If you guys want to pursue the flyback pulse it's ok, I just don't know how your going to test for it. But we could test for the tube voltages with the tools Timmy has..... Either thing could be just a tail chase anyway.... ..
