Old 09-22-2023, 03:55 PM
Originally Posted by Turle View Post
Turns out it was the 150k between the height and linearity pot. Looked fine in circuit but pulling it out showed that it was measuring over a Meg. I replaced it and the height works fine now
Told you so !! Gotta watch resistors in circuit. Low ohms you can get away
with a quick check. The higher ohms you go, the more the circuit
effects readings. Even a slightly still charged cap will throw things off....
Well done !
Zeno
