Old 09-19-2023, 08:17 PM
Turle Turle is offline
Need help with a CTC-15 vertical problem!
I’m working on a ctc-15. Everything was going smoothly until I noticed that I can’t adjust the height at all. The picture looks squashed. The height pot is good. All the resistors in the circuit are good, I checked all of the capacitors. Swapped out the vertical output tube and nothing. The grid of the vertical output wants 30 volts, but jumps around between 3 and 5, adjusting the control only changes it by half a volt or so.
Would anyone know what could be causing this problem? I’ve been stuck on it for days now
Old 09-19-2023, 09:51 PM
you are sure that the convergence PCB is plugged in and working correctly, cause if is not plugged in and working, it wont get the right load/ feedback and you will only get half sweep.
Old 09-20-2023, 12:33 AM
reeferman's Avatar
I know you said you checked the caps, but if it's pulling up from the bottom sub the 50 mike on pin 3 of the output.
It fixed a lot of them 50+ years ago.
But then again that was 50+ years ago.
Old 09-20-2023, 08:32 AM
If the pix has good lin & caps are fresh its usually one of the
high ohm resistors feeding the height control. You have to
lift one end to properly measure them.
Old 09-20-2023, 08:39 AM
And is part of the feedback loop mentioned above, the 50uf cap & 5.6k resistor on the cathode is tied to pin 2 of the socket of the convergence assembly, found out the hard way that weird stuff happens when not plugged in and loaded correctly!
Old 09-20-2023, 08:59 AM
Most common cause is the electrolytic coming off the cathode of the vert output. Plate load resistor of the vert oscillator often goes 'waay off spec (high) due to being hammered by high level spike.
Old 09-20-2023, 03:58 PM
This is not a widescreen program. The linearity looks fine. There is just not enough deflection
Old 09-20-2023, 06:31 PM
Originally Posted by Turle View Post
Attachment 206077
read through this thread, and what he had to do to get full screen back :O
http://videokarma.org/showthread.php?t=271514&page=5
on MINE, a CTC-16xl i had to replace what is R105 & R106 on your CTC-15, the resistors on each side of the height pot, they were way off on mine.
Old 09-20-2023, 08:22 PM
You indicate all resistors check good. But double-check R104. It's a 2.2 meg half-watt, going to pin 8 of the 6GF7. It's the plate load resistor of the vert osc. https://www.earlytelevision.org/pdf/...ams_0673-2.pdf
Old 09-21-2023, 12:09 PM
It’s measuring about 2.5, I figured it was close enough to being within tolerance that it wasn’t causing the issue
Old 09-21-2023, 12:18 PM
Yep. Scratch that one off. A good thing to bookmark though. It's a frequent failure point in designs that run the vert osc from B Boost (not just RCA)
Old 09-21-2023, 12:51 PM
If you have checked all the resistors involved, and know that they are OK, and same with all the caps that could be causing the issue, cause they often can be a bit sneaky and leak at operational voltage, and hard to really test unless you have a tester that will push it to it's limits like the vintage cap testers would, but if you are sure the caps are good, and the boost voltage is within the correct range, one thing to try is a resistance test of the vertical winding of the yoke, YEL & YEL-BLK terminals, should be about 23.5 ohms.
Old 09-22-2023, 07:50 AM
Turns out it was the 150k between the height and linearity pot. Looked fine in circuit but pulling it out showed that it was measuring over a Meg. I replaced it and the height works fine now
Old 09-22-2023, 08:23 AM
Glad to hear it!
That seems to be a common fault, cause as mentioned, it was also just as bad in my set.
Old 09-22-2023, 12:40 PM
kvflyer kvflyer is offline
Another congratulations that you found it. Gosh, sometimes we just have to scratch our head!
