Old 08-28-2024, 11:55 AM
John Marinello's Avatar
<-- "Byron"
Is it just the photo, or is that 12LP4 aluminized? 12KP4??
Old 08-28-2024, 01:33 PM
No, it's not aluminized.
Old 08-29-2024, 05:27 AM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
At least the ceramic inductuner shaft is unbroken.
A 100 q-tips later
How did you get that tuner cover off? It has small phillips head screws behind the RF towers and I can't get to them.
Lee
Old 08-29-2024, 09:30 AM
Needle nose pliers and patience
Old 08-29-2024, 11:27 AM
M3-SRT8's Avatar
Ah. No easy way. Just like when I cleaned up an RA-105B tuner 20 years ago.
Lee
Old 08-29-2024, 01:06 PM
Who's up for a challenge? Speaker cone is trashed and output transformer primary is open.
New cone has been ordered and I dug up a transformer I think will work. At least it's the same size and has continuity.
Old 08-29-2024, 01:11 PM
Meanwhile, I patched the set up enough to try a full power up. Relay is still bypassed and power resistor just tacked in place.
Need to dig up a new eye tube too.
Also, discovered the flyback is a replacement and not secured very well.
Replaced HV cable with more convention HV cup and rigged up a 5AXP4.
After a few pops and cracks that made me jump, we have a raster!
A lot of control fiddling later, we have an image. Tuner seems to be off by a couple channels.
I'm both surprised and relieved this set actually produces an image after all it's been through.
Some tube swapping and more control twiddling and we have a decent image.
Mind you I have no shields installed and am feeding a signal in with alligator clips.
Old 08-29-2024, 07:59 PM
Lee
One thing you can do is remove the IIRC 4 Philips screws under chassis that hold the tuner to the chassis and with the tuner loose you can get to those screws....I will add the caveat that Ive never owned a square dial 103 (only both versions of the round dial) so I don't know if the square dial tuners allow you to do this as easily. I've had at least 3 RA-103 tuners off in the something like half dozen RA-103s I've benched. Two were to swap when I was making a good chassis out of 2 mouse eaten ones, and the other was to deal with a snowy picture issue...That one it turned out that a mica in the lower compartment of the tuner that coupled the antenna to the RF amp had a snapped off lead at the cap body.
Old 08-31-2024, 10:29 AM
Just about done, but have one annoying issue.
The dial scale is off and I can't tune below channel 4!
Now the cam kicks in at the right spot where it spreads out the FM radio portion but LO is off.
Closer examination revealed that when I am tuned as low as it will go, there are still a couple turns left on the coil.
When I'm at the top of the dial, the coil is nearly at the opposite end.
It seems like I need to bump all three coils over one turn.
Is that even possible and, if so, how? Short of taking it apart that is.
Is there a way to adjust the mechanical stop?
Old 08-31-2024, 11:57 AM
It sure looks like one could tweak C23 to shift the LO. Not sure if I can get at it easily or if that would also require tweaking C16 and C17 to track properly.
Old 08-31-2024, 03:13 PM
Bob, if you have full shaft rotational travel stop to stop, just pop out all 3 sliding contact fingers (one under each coil) and reinstall them on the end winding. Just push them out from the side with a small screwdriver. I always pop them out to clean them. One coil is reverse spiral so one contact goes in on the opposite end from the other 3.
Old 08-31-2024, 03:31 PM
Yikes. Do they really come out that easily? That big IF can will make one section extra tricky.
Before I attempt, I want to double check reception at the upper end of the dial.
Old 08-31-2024, 03:43 PM
Yes, upper end also off by about two channels. Ok I'll give it a try
Old 08-31-2024, 10:27 PM
Well, down the rabbit hole we go...
I removed the stop and turned one more rotation towards the low end and it's now cleaned and lubed.
Old 08-31-2024, 10:28 PM
So, the rollers are all shifted over one rotation now. Did it solve the problem? Sort of.
Yes, I can receive 3 and 4 now, but 3 is smeared over a big range. I think I need to adjust the cam behind the dial that alters the action through the FM band. Upper VHF reception seems a bit degraded but the goal to get clean 3 & 4 has been achieved.
