Old 09-15-2012, 09:29 PM
David Roper's Avatar
console lover
Originally Posted by Jeffhs View Post
I doubt if a Muntz set would work at all with a DTV converter box fed by an indoor antenna; if it did, the performance would probably be so-so or worse (read nonexistent). I tried antenna reception on my analog TVs when I moved here almost 13 years ago and could not even get the NBC affiliate in Cleveland......................................... .................................................. .................................................. ...................................
How well the converter box works with an antenna has zero to do with what type of set is connected to the box. Zero. I could've sworn this had explained to you before.
tvontheporch.com
Old 09-16-2012, 02:37 AM
miniman82's Avatar
First Light: 1952-2011
Originally Posted by John Folsom View Post
Nick, you obviously have too much free time.
I didn't make that, only posted it!
Evolution...
Old 09-16-2012, 08:04 PM
Sorry about that. I should have stopped and thought awhile (a good long while) before shooting off that post. You are correct -- since the box is actually connected ahead of the TV's own tuner, the make, model, vintage, etc. of the TV itself makes no difference. I've seen in this very forum posts showing 1950s and even late '40s TVs on DTV converters, and the sets work quite well with them, showing good pictures. Since the TV itself is basically just acting as a display (the set's own tuner and IF circuits are processing only the channel 3 or 4 RF output signal from the box and not an OTA signal from an antenna), the converter doesn't care if the TV it is connected to is five or 55 years old; the converter will work regardless. The same reasoning may be applied to VCRs and DVD/Blu-ray players -- they don't give a darn how new or old the TV they are used with may be; the units will work just as well, except of course with b&w NTSC TVs the picture will not be in color or in HD.
Old 09-16-2012, 08:15 PM
AiboPet's Avatar
AiboPet AiboPet is offline
"micro" and quirky
Location: I'm in San Diego, but lived in Hong Kong for a long time
I have had a DTV converter overwhelm my little Sony S8-301....which otherwise does pick up stuff just fine from my little in-house transmitter (OTA).
If I were to look into it though....this may be handled by just looking at gain or AGC.
My current "holy grail" is trying to get enough parts together to get a Singer TV6U going. Been kicking my ass for nearly a year now :-P
Old 09-17-2012, 05:17 AM
david9091 david9091 is offline
Hi everyone i hope you are all fine ........ i would like to say thanks for this post because it has nice and useful information for us ......... thanks a lot ....... keep it up
Old 09-17-2012, 03:17 PM
console lover
Don't call our banana phone, we'll call yours.
tvontheporch.com
