Ugh, sorry to hear about the smashed cabinet
![]() I found even more production changes and service notes in Riders volume #8 including the addition of the color adapter in run #6. The ETF only has a scan from volume 6. Thanks for looking. If you donlt have the cover, I'll try to cobble something together. My parts order is scheduled to arrive tomorrow just 48 hours after I placed it ![]() PM sent with email address. Quote:
Bob,
I checked. I have the entire IF strip/chassis if you need it. But the damaged set was missing the IF bottom cover as well. Sorry. I have a yoke, flyback, focus coil, rubber CRT bell cushion, the old electrolytics (for stuffing purposes), the color adapter dummy plug, tuner and a few other items. |
BTW,
After the set was working just fine on the bench for about 2 hours, I heard a pop and the picture looked like this. Linearity control was able to fill the screen but linearity was even worse. Height control didn't do much. Changed a few resistors to no avail. I tried a substitute cathode capacitor on the 6S4, thinking maybe it went south. I was disgusted so I let it sit for several weeks. ![]() Look at the voltages of the vertical section. The problem was staring right at me but I didn't see it. The voltage on the plate of V401A, the Oscillator was 175 Volts instead of 100 Volts. The next key was rotating the height control did not change the voltage. Hmmmm. ![]() Long story short, one of the guys mentioned tin whiskers. I took out the 2.5 meg height control and cleaned it up. Problem solved. Must have had whiskers! Now, it works just fine. Just a heads up for your |
