That IF transformer below deck is a really ugly design.
![]() I resemble that remark.
The pin drive speakers were used where the field coils of electrodynamic speakers were impractical due to power requirements, as in some farm sets of the thirties, where battery power needed to be conserved. This type of speaker was abandoned once good Alnico magnet PM speakers came along in the early forties. Interestingly, at least one transistor radio, I believe a G.E., used a pin drive speaker due to space requirements, in the early sixties.
Basically it was a typical TRF of the day. Re: the resistance line cords. Like everything else that can be misused and abused, the cords were no more of a hazard, than any other heat producing product of the day. The higher wattage ones were insulated better. They looked like iron or toaster cords of the day. If in good condition, they only got warm to the touch. Not hot enough to cause a fire. |
It's not quite so cramped after a recap.
![]() I also installed a polarized plug with the neutral going to the chassis. The power switch was rewired to be on the hot side and 1/2 amp fuse added. ![]() It plays surprisingly well ![]() The chassis sure gets hot though. It seems the brass shield collars around each tube base draws a lot of heat into the chassis.
What is the best (or safest) way to connect a polarized line cord to an AC-DC radio or TV currently using a non-polarized one? Every one of my antique radios, including the Zenith H511 on which I replaced the line cord, has a standard cord and plug; the latter can be inserted in the wall socket both ways, which could create a shock hazard if the plug were inserted such that the hot side of the AC line was connected to the chassis. However, the Zenith radio, and all my other AC-DC antique/vintage sets, seem well enough insulated (if the back cover is well secured to the cabinet and the knobs are snug enough on their shafts that they cannot be removed without pulling on them) that this doesn't seem to be a problem. I am only asking about the polarized plug so I will have the information available if and when I eventually decide to replace the cord or plug.
Thanks.
I believe that the wide prong on the polarized plug is connected to the cold, or low side of the line, so that's the one to set up to go to the chassis.
However, having said that, you can't trust that your outlets have been wired correctly, so it's still dangerous. I have pondered this situation for years and have not found a satisfactory solution, short of using an isolation transformer. However, that isn't so hard to cobble up from a pair of filament transformers back to back. You only need, for most of these little sets, 20 Watts or so, which can be gotten from a pair of 6.3 V 3 A transformers. |
The important ones to rework, are the Hallicrafters AC/DC type, metal cabinet sets, as most of them weren't U/L approved and definately a shock hazard. |
Hmm, I don't think I've encountered a line isolation capacitor before
Would that be a cap in the AC line between the plug and the rest of the radio ?Or are you referring to an AC line filter cap ? |
That's a capacitor between one side of the power line and the chassis, usually with a high resistance resistor. A poor solution to a problem that never should have existed.
The whole business of making AC/DC radios safe leads to a series of compromises. If you have a true hot chassis set, you have a chance of the chassis being hot depending on how you plug it in. With a polarized plug routing neutral to the chassis, you're OK as long as your house receptacles are wired correctly. Most sets have the power switch piggy-backed to the volume control: it's better for hum reduction to have the neutral line switched but that would put the chassis hot. What most manufacturers ended up doing later on in the history of AC/DC sets was to use a floating ground with cap and resistor in parallel to chassis. You can still get a tingle from such a chassis, so to avoid that they used methods of mounting chassis where no exposed screws are hot or "warm," and lovely maddening captive knob arrangements like Zenith used. Another way I have used is nylon undercabinet chassis screws to replace metal ones on table sets.
