Old 09-14-2012, 04:10 PM
Emerson 540A restoration
I popped open the last unrestored AA5 radio in my collection this afternoon. It's a nifty little Emerson 540A (AKA Emersonette).
Unfortunately, there's a hairline crack along one side. I'll try to glue that up so it doesn't get any worse.
One cap lost it's insides and there's a smoked resistor. Looks like an easy restore
Old 09-15-2012, 12:05 AM
Kevin Kuehn's Avatar
Workin' Late Again
That's a cutie.
Is that can(Merit?) under the chassis suppose to be there?
Old 09-15-2012, 12:15 AM
The radio has been worked on before and it is a replacement IF can, but the original was mounted in the same location. Space is a real premium in this set.
Old 09-15-2012, 03:11 AM
It's a tough set to work on for sure. I'm having to peel away layers to replace the old caps.
Old 09-15-2012, 08:22 AM
At least the newer components are a lot smaller.
It's been about 40 years since I saw one of those. That sets all original, to be sure.
I don't think it has U/L approval either.
The tube shield on the 35W4 or 50B5 must get hot enough to blister your finger.
Old 09-15-2012, 05:52 PM
Reece's Avatar
Reece Reece is offline
From what I can see from the pictures and the schematic on NostalgiaAir, this is a "true" fully hot chassis set with no floating ground? It looks as if the lower rear mounting screws would be hidden by the back cover and so OK. It also appears that the front flange of the chassis slides under a couple of bosses under the speaker opening to hold it in place and so no underchassis screws exposed.
Reece
Old 09-15-2012, 07:04 PM
bob91343 bob91343 is offline
I just want to make a philosophical observation. I am an old guy and these radios were current models to me. I looked at them with disdain even then, thinking how cheaply can something be made and still have it work. The workmanship, design, and component quality was of the lowest order, and the hot chassis exacerbated that.
I repaired many of them, and it was nearly impossible to repair without creating a sort of upgrade, since after market parts were usually better than OEM.
I realize this is a hobby, but prolonging the life of what I had considered a piece of junk seems to be contrary to common sense.
Yes, it's fun, and that alone justifies it. When I see one, my virtual hands reach out to pick at it and savor the delights of my childhood. I want to rock the tubes in their sockets, spray hazardous substances into the controls, push parts around to search for potential shorts or broken solder joints, etc. And of course clean the dial and recalibrate and realign the unit. The speaker probably is raspy from the cone warping over the years. The knobs push on with springs rather than set screws. And a host of other economy measures were used.
I wonder what of today's gear will be thought of in this way, one day.
On the opposite end of the scale, I recently acquired a Hewlett Packard signal generator, model 606. It's a 19 tube behemoth that weighs enough to give even a strong man a hernia, trying to lift it. Overdesign is evident everywhere, with buffer stages to reduce FM when only AM is desired, a hand calibrated dial, and about 120 dB of dynamic range with a meter that is amazingly accurate.
Old 09-15-2012, 08:08 PM
Yeah, it's a hot chassis for sure. I suppose I should install a polarized line cord for safety.
Cheaply made they may be, but they do fetch a nice price on ebay - especially the white, green and red models. Here's a white that recently went for $200!
http://www.ebay.com/itm/Emerson-540A...-/261050587308
Old 09-15-2012, 08:19 PM
Hey there is even a market for Hallicrafters S-38s that also were not much. I used to chuckle at Hallicrafters' slogan, 'the radio that amazes the experts.' Yeah, amazed that someone would actually try to sell something like this.
Sounds like sour grapes but it's not. I tell it the way I see it, and I enjoy working on the stuff. I have restored many units or, rather, refurbished. I especially have a fondness for test equipment, and I have far too much of it.
Old 09-16-2012, 10:50 AM
They used that same cabinet on a pre-war 2 tube TRF set. Those are the ones that are rare. I don't think many of those survived. Pin-drive speaker, resistance line cord and minimal performance.
Old 09-16-2012, 11:41 AM
Reece's Avatar
Yes, a lot of junk was/is made out there, but it's interesting to preserve some of it as historical statements of the time. Some of the four-tube wonders from the early thirties (mantel sets, midgets) were junk, too; only good for local stations, fire and shock hazards with hot chassis and resistance power cords, squawky volume control arrangements that varied tube bias, but I've got a couple and have one of them fixed up, sort of; it "kinda" plays after a total guts transplant. I could imagine some waitress in a depression diner saving up tips to get a cheap little set like this from Walgreens so she could hear Amos 'N Andy and get a few laughs after a long long day on her feet slinging hash.
"Just around the corner,
There's a rainbow in the sky,
So let's have another cup of coffee,
And let's have another piece of pie..."
Reece
Old 09-16-2012, 02:39 PM
I have a Zenith H511-Y (black bakelite cabinet) that still works -- well, sort of. I live near Lake Erie (within a mile of the south shore), so the set gets WJR in Detroit and probably CKLW in Windsor, Ontario, but it's not so good on Cleveland stations. I can only hear one such station, 50kW WTAM 1100, during the day most of the time, but at night the dial lights up with stations up and down the East Coast and the Great Lakes region.
I replaced the crumbling, dry-rotted power cord with a fresh one I salvaged from an RF modulator. I probably should eventually replace the 3-section power supply filter capacitor as well, although the set isn't humming (at least not loud enough that I can hear it) at the moment. This radio was an eBay score about ten years ago and is one of my favorite sets in my collection, next to my 1980 Zenith "Royal 70" 11-transistor AM-FM portable and my 1958 TransOceanic solid-state AM/SW set. I am baffled, however, as to why one antique radio site on the Internet shows the Royal 70's chassis number as 7ZT49, when the radio obviously has eleven transistors.
BTW, I am only 56 years old, so wasn't around during the Great Depression of the 1930s, but somehow I can't imagine Walgreens being in business anywhere in the US at that time (unless the stores were operating under another name). I think the first Walgreens stores opened in the late 1960s or seventies.
Old 09-16-2012, 03:04 PM
I cannot for the life of me imagine how a 2-tube radio could work, even as a TRF set. My grandmother had a 1948 GE TRF clock radio, but that set had four tubes, which makes more sense to me for a TRF radio. The only problem, at least with my grandmother's set and a 1936 Silvertone table set she had, was that these radios would pick up extremely strong stations on at least two points on the dial. Her radios were at her summer cottage, which was located five miles from a 50kW station, so you can imagine how strong that station was at that location -- it came in like gangbusters.
BTW, what is a pin-drive loudspeaker? I am familiar with PM speakers and field-coil ones, but pin-drive speakers are new to me. (Shows my age -- I am 56 years old and hadn't even been thought of when TRF radios and pin-drive speakers were new.)
BTW (2): Thank goodness resistance line cords (aka "curtain burners") are no longer used, having been replaced many decades ago (before tube-type radios were phased out in favor of transistor sets) by actual dropping resistors on the radio's chassis. I hate to think of how many house fires may have been caused by resistance cords which were too close to very flammable curtains.
Thanks much.
Old 09-16-2012, 03:11 PM
I remember patronizing Walgreen's back in the early 1950s; it seemed like an old institution even then.
A pin drive speaker is, as I recall, a magnetic unit. The horseshoe magnet had an armature that was a thin rod, or pin, that connected to the center of the speaker cone, which was a complete cone down to the tip. I used to have one, back in the middle 1940s. (I told you I was old!)
Old 09-16-2012, 04:24 PM
Reece's Avatar
Mr. Walgreen started the first store in 1901, and by 1930 had 397 stores. Google is your friend.
Reece
