Old 03-16-2013, 09:18 PM
Robb's Avatar
Robb Robb is offline
4 Pin AC Power cord ?
Anyone know where I can get one of these 4 pin AC Power cords ?
Need it for an old 1978 Sanyo Portable TV (TV is Sears and Simpsons made by Sanyo in Japan Model # ctp 1401.)
The tv is like this
Heres the pins
flickr
Old 03-16-2013, 10:09 PM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
You might make this work, not exact but close
http://www.ebay.com/itm/SONY-4-PIN-A...item27d0db6894
Old 03-16-2013, 10:10 PM
Robb's Avatar
damn, 54 bucks !
flickr
Old 03-16-2013, 10:17 PM
mstaton's Avatar
"Book em Dano!"
did not look at the price but you can search for a Sony cord on the internet. Probably a better chance to find a Sony than Sanyo cord
Old 03-17-2013, 10:25 AM
Exclamation
Not so fast ! 2 pins are for AC , other 2 are +- 12v
Wrong cord & you may see fireworks.
A TV belching sparks & smoke is fun IF its what you want !
good luck
Old 03-17-2013, 11:01 AM
crtfool's Avatar
crtfool crtfool is offline
That cable is 2 pins in with 4 pins out - so you have 2 pairs of ac going into the TV. Do a continuity test on the 4 pins on the TV - 1 set of 2 pins should be connected together, and the other set of 2 pins should also be connected together - now you can just connect a standard 2 pin AC cord to the proper pair and the TV will work properly.
Old 03-17-2013, 01:08 PM
Robb's Avatar
good luck
Good to know. Thanks.
I have no idea how to find this proper cord !
You think Sanyo would have old stock ?
flickr
Old 03-17-2013, 02:11 PM
First of all, the cord shown in post #1, is from an RCA or an RCA built GE.
The cord has four pins on the connector end. Two are used for 120 VAC. Another pair are used for 12 VDC. The DC cord is simular but has the cigarette lighter plug on it and using a different set of pins on the connector end.
Old 03-17-2013, 02:16 PM
crtfool's Avatar
OK - very unusual that it is wired that way.
You should be able to identify the 2 pins that are for the AC circuit, and still use a standard 2 pin AC cord to power the TV.
Old 03-19-2013, 06:00 PM
Robb's Avatar
Heres the pins
flickr
Old 03-19-2013, 06:17 PM
Originally Posted by Robb View Post
Heres the pins
Please include the model # of the set. The pictures in post #1 show a different set.
If we have the proper model number, maybe there is a Sams folder on it, so the pin out can be traced.
Old 03-19-2013, 06:20 PM
Robb's Avatar
TV is Sears and Simpsons made by Sanyo in Japan Model #14062.
flickr
Old 03-20-2013, 08:26 AM
I don't see anything listed in Sams under that number.
They never had much on Canadian products, unless it was an item that was sold here.
I don't know if Sears still has stores in Canada. They closed down a lot of stores in the states.
Old 03-20-2013, 09:10 AM
Robb's Avatar
Just look up 1978 sanyo portable tv. Im sure they use the same plugs.
flickr
Old 03-20-2013, 10:12 AM
Zenith26kc20's Avatar
Zenith26kc20 Zenith26kc20 is online now
I can't really see from the pictures but some of these sets have a switch inside the receptacle to switch to 12 volts or AC. If it does, be careful as the wrong setting can also fry the set.
