Old 05-01-2013, 10:15 PM
twbranch twbranch is offline
I believe the DC pins are used to charge a battery using the 120Vac coming in from the wall. You just need to make a cable with four pins that fit the socket on the television. I could do it but will cost as much as the one you found! Best to make your own!
