Old 02-26-2014, 06:36 AM
Countryford's Avatar
Countryford Countryford is offline
Emerson Find
Found this on Craigslist and ended up bringing it home with me.
It has some water damage. This will need a complete restoration.
Old 02-26-2014, 06:47 AM
Very cool !!
Old 02-26-2014, 06:57 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Ooooh, me likey. Where did you find it? I love the blonde cabinet. I've always had this thing for blondes.
OK....saw the posting in the curbside forums. Great score!
Old 02-26-2014, 08:33 AM
Wow, talk about something different! I will certainly be interested in hearing about this restoration.
I would ignore the cabinet for now (well, maybe blow off the dust). To me, the electronic work is more fun than refinishing, and I find that having a working TV motivates me to complete the cabinet.
Phil Nelson
Phil's Old Radios
Old 02-26-2014, 08:44 AM
egrand
Guest
Posts: n/a
Great score! It'll look nice restored. The insides are in really good shape in spite of the outside. If the CRT and lenses are good then I'd say you made out like a bandit!
Old 02-26-2014, 09:34 AM
I will probably refinish the cabinet first. I was told that I had to do that first.
Old 02-26-2014, 10:28 AM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Only projection TV I've seen with a 6S8 sound detector. Emerson must have been trying to use up old stock...
Old 02-26-2014, 11:14 AM
Suh-Weet !!
Old 02-26-2014, 11:33 AM
The chassis appears to be similar to one used on an earlier 10" console, except for the added metal plate (where the 10BP4 nestled) that interfaces to the projection unit. The earlier 10" set had a strange power supply with about 5 25Z6s and a ton of electrolytics. Looks like some of the holes for the 25Z6s are still there on your chassis.
Update: Found the Sams (#46-folder #25) for the earlier 10" set: Model 606 (console) and there *was* a table model (model 571). Indeed it used a 6S8 and 5 25Z6s.
Old 02-26-2014, 01:07 PM
Einar72's Avatar
I actually have the 571, somewhere in storage. I think it had two Selenium stacks, but I remember a sea of holes where the 25Z6s went. I was quite surprised seeing the Sams showing them installed!
Old 02-26-2014, 07:25 PM
bigaudioal's Avatar
Wow, great score! Love it!
-Al
Old 02-26-2014, 09:50 PM
earlyfilm's Avatar
Eternal Member
Originally Posted by Countryford View Post
. . . . It has some water damage. This will need a complete restoration. . . . . [/URL]
There seems little unknown liquid damage on either the speaker or the back panel. The pattern of the spill (dark rim) suggests a solvent spill and not a water issue.
If it were me, I'd test a chemical striper (in a spot that does not show) before trying sanding. If you can remove it down to an even color, it should be easy to replicate the original finish without excessive work.
James
Old 02-26-2014, 10:16 PM
ggregg's Avatar
ggregg ggregg is offline
Cool set, good for you! Looks like a lot of work, but well worth it in my book. How many people have one? Not many.
Old 02-27-2014, 04:08 PM
truetone36's Avatar
electronics packrat
Nice! How many different sets use the Philips Protelgram system? I've seen this setup in a few different makes of set.
