Old 04-21-2014, 08:40 PM
cjacek cjacek is offline
Question What is this connector?
Hi,
I just picked up one of the earliest U-Matic recorders, the Sony VO-1800. Does anyone know what kind of a connector this is (video out)? It's the biggest one in the photo. Looks like a coax but much larger. Thanks for your help.
Old 04-21-2014, 08:58 PM
WISCOJIM WISCOJIM is offline
Looks like an SO-239 socket for which you'd need a PL-259 plug.
http://en.wikipedia.org/wiki/UHF_connector
Old 04-21-2014, 11:08 PM
EdKozk2 EdKozk2 is offline
Tinker
Just like CB antennas use.
Old 04-22-2014, 12:04 AM
Thank you very much. So I could use an adapter like this to connect it using normal RCA cables?
Old 04-22-2014, 05:14 PM
Yup!
I made my own adapter by cutting an end off an RCA patch cord and soldering a PL-259 plug on. Works great with my Sony VO-1600. I don't know if this is the case with the 1800, but the 1600 has a built in RF modulator.
If it starts loosing color synch and wanting to run too slow for the H and V synch to work (color seems to be the first to go) try flipping the belts inside out so the face that contacts the pulleys does not.
Old 04-23-2014, 12:48 AM
Thanks Tom.
