Old 08-02-2014, 10:48 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
You mean there's a fine-tuning control for each VHF station? I saw that on a RCA portable before. If so, couldn't hurt to give it a twist.
Old 08-03-2014, 07:39 AM
Console User Console User is offline
Yes, there's a fine tuning for each VHF channel on the dial. I might try to tweak it a little today & see if it helps or not? I have noticed that I have to have AFT switch On. If I turn it off the TV isn't as clear & also makes a static noise similar to what we use to get on an analog station when it was fading in and out.
Old 08-03-2014, 10:48 AM
Went and adjusted the VHF for Ch.3 it is now possible to run the box on Ch.3 now. I am blooming a little red on the outlines of certain pictures. Would it help to go in and turn down the red drive on the back of the set??
Old 08-03-2014, 11:10 AM
That's known as color bleeding. The CRT has seen better days.
Old 08-03-2014, 11:39 AM
Yes, I have heard it referred to as color bleeding. However,my TV Tech Repairman has also referred it as blooming. I will add this note as well. This color bleeding isn't occuring on the retro shows that were made back in the days of this style of set. It is just more pronounced on the new broadcasts and even that it's not terrible. We will probably keep on using it the way she is.
Old 08-03-2014, 01:39 PM
BLOOMING symptom is the pix will expand as brightness goes up.
With changes of scene it will "breathe" in & out. Very common on tube
sets but very rare on solid states.
BLEEDING or FLAMING is a streak to the right of a bright scene.
Can be one color or any color or white. Almost always weak CRT.
Turning up brightness & contrast make it much worse.
BTW since you have a "knob job" tuner forget the cable switch.
There are 12 presets for VHF fine tuning, one for each channel.
It is a screw so you can turn it quite a few times. Most the time
you can go to the next channel, ch5 can go to ch4 or ch6.
Proper way to FT is turn off any AFT & auto color switches,
fine tune for best pix then put the AFT on.
Old 08-03-2014, 03:31 PM
I changed my Converter Box to a different brand and this seemed to help with alot of the situtations I had explained above.
Old 08-04-2014, 10:36 AM
I love the name "knob job" that is clever!!
