The replacement chips come with a pair of 18 pin sockets. I'm planning to use them.
I have to practice de-soldering. It's been years since I've replaced any IC's.
Bruce |
If you have a good desoldering pump, you should be able to do it easily. ![]() |
Don't have a desoldering pump. Only have some wick material.
Bruce |
If you only repair for metal circuits, probably not but if you also repair some circuit boards . you absolutely need this tool ..This tool will make a better job |
